Old 01-31-2007, 09:15 AM
sbond sbond is offline
Default trouble with MIDI drum loops
ok, i am trying to use reason adapted's drum loops on pro tools 6.7. the only problem is that i dont have a MIDI controller, how exactly am i supposed to use these loops?
Old 01-31-2007, 09:44 AM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
Default Re: trouble with MIDI drum loops
I'm assuming you're referring to the Rex loops - if so, you can drop them into the Dr. Rex module and then click on the 'To Track' button in Dr. Rex to put MIDI notes in the Reason sequencer that will play back the Rex loop.
Avid Audio Tech Support
Support FAQ
Old 01-31-2007, 03:15 PM
the only drum machine that i have in reason is REDRUM. i was told that i could use the pencil tool and then drag and drop the loops into pro tools but i havnt been able to do that with the ways tat i have tried.
Old 01-31-2007, 06:20 PM
You can't Drag & Drop ReDrum Patterns, you'll need to either use the ReDrum Pattern Sequencer to programme or use the factory default Patterns or use the Pencil tool in Pro Tools for triggering ReDrum Samples from patterns you construct yourself.
However, you can Drag & Drop REX files from the DigiBase browser, but this is a little more complicated and for further information concerning this subject, consult your DigiBase Guide (this applies onlt to versions 7 and higher).
filosofem
Aaron Mulqueen - 001 HD Native
Having trouble putting drum loops into the session from the Workspace window in Proto gibsy Pro Tools 11 1 12-17-2013 12:05 PM
editing drum loops in PT MIDI timos MIDI 2 01-01-2011 01:09 AM
midi drum loops guitardom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-26-2006 11:43 AM
DRUM LOOPS AND MIDI Abomb97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-16-2003 03:57 PM
Drum Loops - audio vs Midi Cliffy_Boy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-09-2003 11:54 AM
