Old 10-19-2018, 06:10 AM
TrackerLe TrackerLe is offline
Default How to exclude HDX as core audio Device...
Hi Forum, I hope you can understand the title...
My Problem... I don t use the HDX Card as Core Audio Device, but the fan of my card always spins up, although i dont use the HDX Card. My Source are the internal Outputs of my Mac Pro. I want to use the HDX Card only in Protools Ultimate. How can i disable the card as Core Audio Source...
Even if i don´t use the card outside Protools, the Fan of the Card is running... If i uninstall the HD Driver, the card is quiet.
How can i tell the driver, that the card is only used in Protools. You know, the fan is very loud and if i don´t use Protools, i don´t want to hear it...
But the Fan starts to run. It doesn´t matter, if i select another Audio Output in the system settings of OSX... What can i do... Thans for help
Old 10-19-2018, 09:17 AM
YYR123's Avatar
YYR123 YYR123 is offline
Well for the record in Windows you can set the default device for Native playback (read: core audio, OSX sound)
I haven’t used Mac in such a long time idk if you can assign functions like that for Mac.
Daniel
Old 10-19-2018, 12:18 PM
BScout BScout is offline
Default Re: How to exclude HDX as core audio Device...
You can remove the CoreAudio access of the AvidAudioServer for HDX (pro tools doesn't use that for access anyway) and it won't be available to anything but Pro Tools then.
See here:
http://avid.force.com/pkb/articles/e...e-Audio-on-Mac
If you wish to uninstall the new HD Driver you can simply delete the AvidAudioServer.app file located in /Applications/Avid/AvidAudioServer/
That's all it takes (and reboot the computer so that program isn't running in the background anymore.) It will no longer show in Audio MIDI Setup or System Sounds as an option but will continue to work with Pro Tools.
Pro Tools Ult 2019.5, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 10-23-2018, 05:27 AM
Hi BScout...
You are my hero... Thank you very much for your help.
The Tip worked. I moved the AvidAudioserver App out of the App Folder and
now the hdx card stays quiet until i use it with Protools Ultimate.
The great thing is; If i need Core Audio, Logic Pro X for example, i can start the avidaudioserver app manually and HDX comes up as Core Audio Device... Thank you
Old 10-25-2018, 08:05 PM
685 685 is online now
This thread helped me solve the totally opposite need. LOL
For some reason my native card stopped showing up in CoreAudio. I reinstalled the HD drivers as well as protools several times with no luck. Read through this thread, searched for the AvidAudioserver.app, double clicked it (and the AvidAudioserverlauncher.app) and it's all is back to normal. Fingers crossed
Thanks
2018.10
OS 10.13.6
Old 10-29-2018, 04:57 AM
Hi 685
Thats great to hear... The AvidAudioServer.app seems to be the key for core audio functionality...
Exclusive Control of Audio Device or Cannot Initialize Device Alexlimbert Pro Tools 12 4 10-22-2017 04:41 AM
exclude clip from selection - shortcut johannes1 Tips & Tricks 2 10-10-2016 06:02 AM
Digi 002 + PT 8.0 from Windows to OSX - Unsupported Device in CORE AUDIO MANAGER whoman421 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-03-2012 07:43 PM
digi core unsupported device andu Pro Tools TDM Systems (Mac) 10 12-03-2008 05:33 PM
Exclude loop mode? carson Tips & Tricks 0 05-06-2000 04:04 AM
