How to Join & Post  ē  Community Terms of Use  ē  Help Us Help You
Knowledge Base Search  ē  Community Search  ē  Additional Resources
Old 09-29-2018, 11:20 PM
ProtoolsLover ProtoolsLover is offline
Default HD Native with Apogee AD16
I recently added an apogee AD16x to my HD native system. Itís saying it as an HD I/O digital 16, vs an analog I/O. Iím running macOS high sierra. Iím guessing I just need to do a firmware update on the unit, but before I did that, I wanted to see if anyone else that had any issues running an older apogee AD16x?
Old 09-30-2018, 05:46 AM
LDS LDS is offline
Default Re: HD Native with Apogee AD16
It should appear as a HD I/O Digital interface in Pro Tools. Prior to the firmware update they appeared as Digi192 Digital interfaces within Pro Tools. It is only in recent years that third party manufacturers have technically been given access to the digilink protocol by Avid. Prior to that, manufacturers like Apogee reverse engineered their own solution.
Have a read of the Apogee X-HD manual when you get a chance. Specifically the differences between the advanced and normal routing options you have.
littledevilstudios.com.au
Pro Tools Ultimate 2018.12. OSX 10.13.6. HDX. Avid Omni. Mac Pro 5,1 12x 3.33Ghz. 64Gb. 4x mSata SSD Drives + 4x HDD. Blackmagic Intensity PCIe. ATI Radeon HD5770.
Free Lexicon 224XL Impulse Responses
Free Sony DPS-V77 Impulse Responses
Old 10-01-2018, 05:39 AM
JFreak's Avatar
JFreak JFreak is online now
Hi, welcome to the community.
No you do not need a firmware update, because it shows up as Avid HD interface. The older firmware made it show up as Digidesign interface.
Janne
Old 10-01-2018, 01:55 PM
When trying to troubleshoot, I reset the unit to factory setting, which took the firmware back to the original one. There have been multiple firmware updates since.
Old 10-04-2018, 01:16 AM
LDS LDS is offline
Factory reset doesn't touch the firmware in the 16x or X-HD card. Apogee actually list a factory reset as the very last step in the process to upgrade firmware!
Old 10-04-2018, 03:45 AM
JFreak's Avatar
So just pick the latest one and be happy with it. I have had close to zero problems with any Apogee firmware, and the one problem that I had was a result of a faulty card, which they replaced as it was under warranty.
Janne
Old 10-04-2018, 10:59 PM
I understand.....FWIW, I updated both my AD and DA 16 to the most recent firmware.....
Apogee AD16/DA16 Emi Pro Tools 2018 7 02-28-2018 10:11 AM
Apogee AD16 + two 888/16 ? T-Low Pro Tools TDM Systems (Mac) 2 10-28-2003 07:21 AM
192 I/O vs Apogee AD16 cjguitar Tips & Tricks 28 11-20-2002 03:50 PM
Apogee AD16 Gil Parente Tips & Tricks 3 11-07-2001 06:55 PM
Apogee AD16 Fokke van Saane Pro Tools TDM Systems (Mac) 2 08-06-2001 07:14 AM
