Old 09-19-2018, 08:05 AM
nucelar's Avatar
nucelar nucelar is offline
Default Quick Question HD Native Thunderbolt
Hi, I have a quick question regarding the Thunderbolt box. I could not find it in the manual...
Can I use it without actually connecting an I/O interface device (like an Omni)? i.e just using the onboard headphone output?
Does it show as an audio device in System Preferences when in this state (without I/O)?
I'm having problems detecting it under 10.13
Thanks!!!
Old 09-19-2018, 09:44 AM
Southsidemusic's Avatar
Southsidemusic Southsidemusic is online now
Default Re: Quick Question HD Native Thunderbolt
Doubt that will work as the TB Box isn't an interface on its own and PT needs an interface or built in soundcard to work. Why would you want use that box for a headphone unit anyway?
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 09-19-2018, 09:51 AM
BScout BScout is offline
No.
(And btw, the headphone out isn't done in the TB box. It is a re-route back from the audio interface via the digilink cable and is always on the 1-2 out on that interface. Nothing is done by the TB box itself)
Pro Tools Ult 2018.12, HDX 3, MTRX/SPQ, HD Omni • Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6 • RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 09-19-2018, 03:09 PM
nucelar's Avatar
Thanks both for the reply, tomorrow morning I will try connecting an HD I/O and see what happens.
I was doubting because in the product info (https://www.avid.com/es/products/pro-tools-hd-native) it says
"And it offers easy connection to the latest Mac and Windows-based desktop and laptop computers for dedicated studio use or on-the-go creation."
I find it a bit misleading to call it "on-the-go creation" when you need a mains-powered rackmount unit to make it work
Old 09-19-2018, 03:22 PM
JFreak's Avatar
JFreak JFreak is online now
Sure it can be understood as a totally battery-powered solution, but coming from the HD world the wording is easy to understand. Before that little box we needed to carry a full desktop workstation to connect to the HD interfaces, now that gear can be connected to a laptop via HDN|TB
Janne
Old 09-20-2018, 01:21 AM
nucelar's Avatar
Problem solved!
I connected an 192 I/O and everything works fine as expected!
Thanks again!
Old 10-08-2018, 07:51 AM
John S. Hetrick John S. Hetrick is offline
Problem solved!
Thanks again!
If you don't mind me asking, how did you hook this up? Which cable?
Thanks!
Old 10-08-2018, 10:10 AM
JFreak's Avatar
You only need mini-digilink to digilink adapter to be able to connect old HD interfaces. Unsupported, yes, but works as expected
Janne
Old 10-10-2018, 10:48 PM
Extreme Mixing Extreme Mixing is online now
But if you want to travel, all you need is your iLok key and you can use the headphone jack on your computer. It works perfectly. You can't record, but you can mix and edit and get lots of work done. No thunderbolt and no 192 required.
Steve
Steve Shepherd
Extreme Mixing
Old 10-11-2018, 03:55 AM
Mark Ziebarth Mark Ziebarth is offline
But you’re sure the headphone of HDN TB doesn’t work when no interface is connected? I remember they told about the good quality and the high level of the headphone output... or am I wrong? I’m thinking about getting one and would use it half of the time with headphones only (when at home or on the road).
Best
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac Pro 2008, RME Fireface, Pro Tools 12, Euphonix MC Control
Question on Avid HD Native Thunderbolt Core Joe Courtney Pro Tools HDX & HD Native Systems (Mac) 9 01-22-2017 11:42 PM
HD native thunderbolt/192 question joehaven Pro Tools 11 1 10-23-2015 02:32 PM
Quick question for an HD Native Thunderbolt owner HearInc Pro Tools HDX & HD Native Systems (Mac) 24 08-13-2015 11:27 AM
Native Thunderbolt Adapter question musicmixer04 Pro Tools HDX & HD Native Systems (Mac) 0 04-23-2015 07:10 AM
HD Native Thunderbolt question Norrie Pro Tools HDX & HD Native Systems (Mac) 9 01-07-2015 12:11 PM
