Tapping to Memory Location
Hello, I'm currently working on a session with hundreds of memory locations, which I'll have to step through one and all in order to separate a huge clip - my question: Is it possible to tap from one memory location to the next? I'm aware of the keypad shortcuts, but that wouldn't really save me any time.
Thanx, fellas! |
Re: Tapping to Memory Location
You can click into the bar, where the markers live, and while holding shift, click into the track(s) you want to do edits on.
Now hitting the "tab"-key makes the cursor jump either to the next marker, or to the next region border in one of the marked tracks.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Didn't work for me. Always jumped to the next region border (I tried it with a tap to transient setting, too, but then it did just that). Am I doing something wrong?
My bad, obviously, this doesn't work with PT10 anymore. Last time I used it must have been on PT8 or earlier.
What does work though is clicking in the markers-bar only, and then hitting tab. This jumps from memory location to memory location. Then do a shift+click to the track, you want the edit to be done, then press command+e to separate. Then you start over again - click in the marker-bar, etc. It's fairly fast, once you got the hang of it.
Keyboard shortcuts are the fastest workflow in PT but it takes time. It did for me anyways but I could never go back.
Looking for Memory Location Timesaver in P.T. 8.0.4 | FrankCan | The Drum Room | 5 | 09-12-2013 10:12 PM |
Memory Location | mmf78 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-02-2007 01:15 PM |
Memory Location Assistance | xianny | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-27-2005 10:39 AM |
6.1 bug: Can't add memory location | tal herzberg | Pro Tools TDM Systems (Mac) | 1 | 07-31-2003 01:01 AM |
using memory location window | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-14-2002 10:36 AM |
