Why don’t I get sound out of my Right speaker
Ever since I’ve been using Protooles le 5.3.1 I notice that there are times while using Digi 001 in monitor mode and editing MIDI notes I only hear sound from the left monitor. I had spoken to some one at the protools support center who said I should use a balanced cable. This seem to have temporarily solved the problem which recurs from time to time. I had all cables plugged out and the digi was disconnected for about a week due to some studio renovations. Now I have reconnected all and the problem came back. I have checked all my I/O and they are fine. The Fact is that when I play back a song in audio I get left and right And If I hook up my keyboard outputs to my monitors I hear left and right. It is only on the MIDI playback via Digi 001 >keyboard> monitors and keyboard program/combi playback>Digi001>monitors that I don’t get the right. So I don’t know if the problem is the Digi 001 or the synthesizer. Does anyone have any ideas?
Thanks
Soliloquay |
Re: Why don’t I get sound out of my Right speaker
I have this problem occasionally with a 001. For me, popping the monitor mode button in and out a few times fixes it.
Greg
Protools PC, i9 10990, Gigabyte X299 mobo, 64 GB ram, EVGA Nvidea GT 720 TI video card, Win 10 Pro, PT Ultimate (Native) 2024.3.1, HD Omni, HD I/O 16x16 . |
This solution may not apply, but i got to put it out there....
----------------- I have a similiar problem, but only when my monitor volume knob is turned down real low. To fix it, I turn the monitor volume up to 1/4th of the way, and adjust the master volume within protools to compensate for the output level. Dova |
Sound slike you suffer from a known hardware bug with the 001, bad solder points. they can cause low, no or intermittant levels on the analong i/o, and problems with the pots on the front as well. If you're handy with a soldering iron the solution is pretty simple. Open the unti and resolder all the connections to the PC board from i/o connectors and pots. this should solve your problems.
Like said, I usually keep mine in between 9 and 12 oclock.. it has never had a problem in that range.. tim |
Thanks everyone for your comments. The sound in the right speaker already returned. Also thanks much for COMMENTS webmaster
Soliloquay |
Sound through only one speaker (Pro Tools 10) | JustinWellin | macOS | 1 | 06-29-2012 11:23 AM |
No sound form right surround speaker | akotian | Windows | 3 | 02-28-2012 04:40 AM |
strange speaker sound......PLEASE HELP | boabyd23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-25-2009 07:02 AM |
sound from under the speaker | bad jitter | Post - Surround - Video | 1 | 10-14-2008 09:26 AM |
c/24 no sound in left speaker out | raga2000 | ProControl, Control|24, Command|8 | 2 | 06-04-2007 02:11 PM |
