Old 09-25-2003, 10:04 AM
wild eyed wild eyed is offline
Default 888 audio interface and mixer question
In my 888 manual it states that the inputs are balanced,does this mean that i MUST plug my mics into a mixer with balanced outputs and then plug into the 888 to be able to record? or can i somehow bypass the mixer and go straight to the 888? im asking because i want to know if a mixer is important espically if i will be doing my mixing using protools.
thanks
Old 09-25-2003, 10:39 AM
Default Re: 888 audio interface and mixer question
This is such a basic question.. that it almost begs the question.."Whet the heck are you doing with a TDM rig?".
Basic audio engineering.. what's the difference between a Microphone and a Line level?
The 888 can be set up either as +4 or -10.. a microphone needs a lot more gain before it'll atain that kind of level.
A couple of book suggestions: Home Recording For Musicians For Dummiesฎ or Modern Recording Techniques.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 09-25-2003, 03:35 PM
ok sorry, i was able to record a vocal without using a mixer last nite, but i was told that i would require a mixer, without the mixer the vocal was slighly distorted, with a mixer would this be avoided?
Old 09-25-2003, 07:59 PM
Johnny Jam Johnny Jam is offline
You really sound like you are serious!!
Well, you need a preamp for the mic to get a proper level and avoid distortion. Many mixers has built-in preamps, but you can also buy a single preamp that connects to the 888. They range from about a couple of hundreds to several thousands dollars. Search for "preamp" and you should find many suggestions.
advice about audio mixer stand alone, pt interface and lightpipe converter? alidav macOS 2 03-04-2014 07:31 AM
Mixer style audio interface jwilkers Pro Tools 10 8 09-22-2012 03:02 PM
Mixer vs Audio Interface Beng985 Pro Tools 10 5 06-17-2012 10:18 PM
Audio interface to analog mixer xterraguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-05-2008 11:55 PM
M-audio interface question Digiliz Pro Tools M-Powered (Win) 2 06-19-2006 05:09 PM
