PT 11.3 Stock Plugin Manual
Hi, I went to my account and downloaded the plugin manual under "My Products" but it looks like there are a lot of plugins listed in the pdf that I do not have. Maybe the download manual is for all the plugins?
ex: I wanted to make sure I was reading my levels correctly with the trim plugin so I downloaded the avid plugin manual under my account and looked for the trim plugin. The manual shows a different, more advanced trim plugin than I have. I was hoping to find the correct manual so I can learn about all the features of the plugins I have. Any suggestions are appreciated. thanks, Jeff |
Re: PT 11.3 Stock Plugin Manual
Yes, the manual covers all Avid plugins(many of which you likely don't have). Not sure why anything would look different, unless the manual is referring to an HD version(although most plugins that are in both HD and non-HD Pro Tools look and work the same). What are you trying to do with the Trim plugin that makes this critical?
Thank you for the reply. Yes, the trim plugin I am seeing is probably the HD version. I was confused since the plugin manual was in 'my products' list. Just wanted to make sure I did not have missing plugins from an old install..?
I did do a search online and found a different avid plugins manual that has the actual trim plugin I use. This manual is different than the one in my product list which shows a more advanced version. anyway, do not to spend too much time, but I do appreciate your help. I use the trim plugin on my channels when gain staging. trying to better my mixes. btw, I just go the Avid Pro Compressor. it is cool. Thanks again, Jeff |
Pro Tools Stock Plugin Presets??? | Nico Zottos | AAX Plug-ins | 0 | 12-12-2014 04:13 PM |
Click II plugin not syncing to manual tempo? | Gene100 | macOS | 0 | 10-16-2014 10:56 AM |
HD 10 No Boxed version no manual where can I get a manual HD10 | phatbeatstudio | Pro Tools TDM Systems (Mac) | 4 | 12-26-2011 01:01 AM |
Manual Delay Compensation using Time Adjuster Plugin | deanguidry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-28-2008 09:30 AM |
DVD-R STOCK | soundezign | Post - Surround - Video | 8 | 12-11-2006 03:48 PM |
