Old 02-24-2016, 11:42 AM
sample sample is offline
Default Hopefully an easy one for you guys: Opening 8 KHz sample rate / 16 bit sample size
Hi all,
Having trouble opening files with an 8 KHz sample rate in ProTools. Files are from a phone based recording system, and sound like chipmunks however I set up the session.
Tips for settings? Conversion? Kind of lost here. Probably has an easy solution.
Settings:
Length : 3.1 seconds
Channels : 1 (mono)
Sample Rate : 8KHz
Sample Size : 16 bit
Bit rate : 128 kbps
Type : .wav
Old 02-24-2016, 12:44 PM
Ben Jenssen's Avatar
Default Re: Hopefully an easy one for you guys: Opening 8 KHz sample rate / 16 bit sample siz
File menu: Import audio.
PT should offer to convert it to the session sample rate.
Old 02-24-2016, 01:04 PM
Finally solved it; was doing a very large import (250+) so didn't do the convert step before adding them to the session. Thanks for the quick response; mostly wanted the great minds on it while I fiddled with settings just in case!
Pro Tools 11 automatically changes sample rate when opening infamy Pro Tools 11 16 02-27-2015 06:45 PM
Determine Sample rate without opening Protools JCBigler Pro Tools 11 6 01-19-2014 07:22 AM
Unable to change sample rate or buffer size with 11R MattBaron Eleven Rack 5 03-05-2012 03:39 PM
Finding sample rate in PT session without opening..Is is possible? jarrydee Pro Tools 9 9 01-15-2011 04:40 AM
What sample rate and bit depth are you guys using? MaKoRancid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 01-25-2005 12:25 PM
