Freeze at Initializing Audio Engine
From working through the cause of a freeze at Initializing Audio Engine (after selecting the HDX as the playback engine):
1. Run Digitest to see if the system passes 2. If you have an Avid Omni, reset to factory defaults (Setup button, press Monitor pot, rotate CW to RESET, press Monitor pot twice) 3. Uninstall all Avid software, including Eucontrol 4. Remove all traces of earlier PT installs, esp. earlier Digi audio engines. Uninstalling though Control Panel leaves folders with Digi audio engines. 5. Reinstall PT HD 11 or 12 6. If the freeze persists, replace mobo with mobo with Thunderbolt header, preferably TB2 (unless you can find an Gigabyte mobo in which HDX will work in a mobo PCIe slot; Avid's position is that HDX cards only work in mobo PCIe slots on certain HP Z stations), buy a full-length TB2 expansion chassis, like a Sonnet III-D, and use the HDX cards linked by TB2. The slot population order should be, proceeding away from the CPU: video card, HDX card(s), nic or other host adapter. HD
ASRock X99 OC Formula mobo, Win 8.1 x64, PT HD 12.1, i7-5960X CPU, 32GB G.Skill 2133 RAM, Intel 750 PCIe SSD boot drive, ASRock TB2 AIC, Sonnet Tech III-D with 2 HDX cards on TB2, Omni, HD I/O, S3, Artist Transport, SSDs and spinners, AMD HD 7990 GPUs, 2 HP ZR30w panels on DP. Last edited by maunaloa; 07-17-2015 at 02:07 PM. |
Pro Tools hangs at initializing audio engine | kasman | Pro Tools HDX & HD Native Systems (Win) | 12 | 05-10-2016 09:20 AM |
STUCK on Initializing Audio Engine | piano686 | Pro Tools 11 | 1 | 03-02-2015 03:11 AM |
Pro Tools 11 and MBox 2 Pro hangs during Initializing Audio Engine | SBeats123 | Pro Tools 11 | 5 | 01-15-2015 03:59 AM |
PT 11 Initializing Audio Engine Restarts Computer | ns456 | Pro Tools 11 | 2 | 10-15-2014 12:48 PM |
Help Freeze on "Initializing audio engine" | jeml | Pro Tools 11 | 1 | 03-07-2014 11:52 AM |
