G5 - now official
Says Jobs:- 64-bit processor. The first first 64-bit desktop processor. Runs our existing 32-bit apps no problems. Single/Dual processors. Up to 8GB Memory. Can talk to mem @ 6.4GB/s. G5 System Controller - dedicated bandwidth to each subsystem. 6x faster than G4, 8GB bandwidth, One processor doesn't slow down the other one. 400mhz DDR memory, AGP 8x Pro, 133mhz PCI-X slots. Hypertransport. Serial ATA. 1.5GB/s bandwidth. independent interfaces to each drive. Optical digital i/o and analog i/o, fw800 ,usb 2.0 This is a new generation architecture.
Massivly parallel. Up to 250 inflight instructions can be processed at the same time (The G4 can do 16) Floating point "monster". Very interesting times ahead for our native using brothers and sisters me thinks |
Re: G5 - now official
Bad news, entry level Mac up to $1999 from $1499.
Good news, high end Mac at $2999..down from $3599. |
Please, specify your sources. I haven't seen anything on the Apple site yet.
Yours Ulf
If it ain't broke, don't break it ! |
Here's another:-
http://www.theregister.co.uk/content/39/31382.html 9 fans [img]images/icons/frown.gif[/img] but supposidly 1/2 the noise of the current G4s [img]images/icons/smile.gif[/img] |
Thanks !
So does that mean HD cards won't work in PCI-X slots?
Looking at the Apple store, only the 1.6 ghz SP machine comes with PCI slots. The two faster models have PCI-X slots, and there does not appear to be an option in the customize menu to change these to PCI. Lee Blaske |
The technical overview document has some good info.
When you see how much space the G5s + cooling take up you can see why they had to nix one of the slots. The case looks like it is a vast improvement over the current design. The odd looking front allows cooling across four zones within the computer. The old case never properly drew air through it. Cooler aluminum vs. plastic. You can also get into it without having to pull down the motherboard and all the connecting cables. S/PDIF appears to be able to be clocked externally. Busch. |
Cool machine, but hardly rackmountable 20.1 inch with non removable handles
alos 8.1 inch widht, that's 5 units. let's hope that the G5 xServe will do the job. JC |
[img]images/icons/cool.gif[/img] Ray |
It's Official. | Vercingetorix | Eleven Rack | 23 | 07-20-2011 09:26 PM |
6.4 official or not? | shadowbox | Pro Tools TDM Systems (Mac) | 1 | 04-06-2004 03:17 PM |
It's Official - PT6! | Phil O'Keefe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 10-02-2002 08:25 PM |
It's Official - PT6! | Phil O'Keefe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 10-02-2002 12:29 AM |
