Re: Vacuum patch gets shorter decay time at 96kHz session than 192kHz session
For country and man! Stig.
Aaron Mulqueen - 001 HD Native |
No problem.
Will do it!
I've thought about it a bit, and I don't need to hear it to test it. Sometimes I'm too stupid for my own good.
The track names and waveforms should explain what the test revealed.
I penciled in some 1/8 notes on two instrument tracks with Vacuum, using both presets. Recorded the output from both onto audio tracks. This was the 192 kHz session. Then, I imported everything from the first session into a 96 kHz session, and recorded the outputs from Vacuum onto two new audio tracks. That should do it, no?
Great, thanks Stig!.
So you get the same result as me. I can clearly se that the decay is shorter in the 96 kHz file compared to the 192 kHz file. The question now is why does this happen? Bug? |
#16
Without viewing the Vaccum plug-in setting, how do you know it's the ENV Decay? Are AMP ENV Sustain and Release Off?
#17
It's not a very big issue, because I can increase the decay value (move the knob to the right) in the 96k session and it sound like it does in the 192k session. But if I save the patch in 96kHz and then open it in 192k the decay time is longer than in 96k. I just think this is odd. |
#18
Lodge it with IdeaScale.
#19
#20
As indicated in the Ideascale post, we've been able to repro this and have it logged for a fix.
Thanks for the report. |
Pro Tools 9 crashes every time I open a new session or import session data | Ryan Butler | macOS | 14 | 03-23-2014 07:53 AM |
Is my session 96khz ? | VictorC | Windows | 3 | 01-30-2014 11:23 AM |
192khz session not even an option. | Jakay | macOS | 18 | 09-18-2013 08:09 PM |
Convert 192kHz session to 96 | rososound | Pro Tools TDM Systems (Mac) | 3 | 03-17-2007 12:55 AM |
CoreAudio7.3 works above 96kHz? PT7.3 192kHz woes | Mauro371 | Pro Tools TDM Systems (Mac) | 1 | 12-15-2006 08:44 PM |
