Old 12-30-2010, 12:40 AM
Guibara Guibara is offline
Default PT 9 with no audio interface question
Hi guys,
I'm in the process of getting a Mac Pro to run PT9 without an audio interface, so I'm wondering what I'll need to get the audio out of the mac pro and into my Genelecs 1031s... ???? How about sound quality? Should I expect a not so good audio quality output straight from the Mac Pro?
At the moment I will be just working to video, mainly doing sound and music editing, some cleaning up of audio tracks and maybe some light rough mixing.
I'll probably get an audio interface down the line so I can also record some stuff... but for now I'll rather put all the money towards the Mac Pro and PT9 + Production Toolkit.
Any help will be much appreciated, thanks!
Old 12-30-2010, 01:52 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: PT 9 with no audio interface question
Originally Posted by Guibara View Post
Hi guys,
I would budget for at least a reasonable 2 channel interface for now! the built-in audio is ok for most stuff, editing etc, but not ideal for serious audio decision making.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-30-2010, 02:53 AM
JFreak's Avatar
JFreak JFreak is offline
You should at least have a decent DAC converter between the optical digital outputs of your Mac Pro and the analog inputs of your Genelecs. For example, an Apogee Mini-DAC
http://www.apogeedigital.com/products/mini-dac.php
Naturally your system would be compromised with the internal clock of MacPro but this would still be miles ahead of using the built-in analog line output of a computer.
A small interface could be better solution, overall, but your money is never wasted on Apogee so that's why this is what I bring up.
Janne
Old 12-30-2010, 06:14 AM
nst7 nst7 is offline
You could even get something as cheap as an M-Audio Fast Track ($119). It would still be way better quality than coming out of the Mac Pro direct.
http://www.sweetwater.com/store/detail/FastTrkUSB2/
Old 12-30-2010, 02:22 PM
Park Seward's Avatar
Park Seward Park Seward is offline
What are the specs of the Mac Pro Intel HD audio?
What exactly makes it worse than a $120 interface?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 12-30-2010, 02:44 PM
Thanks for the suggestions guys.
The Mini DAC looks interesting, but a bit pricey I'm afraid. If my only option is to get a small audio interface, I may end up some type of MBox, maybe a used one from the previous generation.
I'll do some more research... if you guys have any other suggestions I'm all ears. :)
Old 12-30-2010, 02:46 PM
Dism Dism is offline
A stereo 1/8" jack vs two individual balanced outputs.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
[IMG] code is Off
Which Audio interface for an Imac & Low latency question stof77 macOS 5 11-07-2012 05:50 AM
Audio Interface question tommytic Pro Tools 9 4 12-22-2011 03:38 PM
pro tools LE and M-Audio interface question crazypunk184 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-15-2007 11:21 AM
M-audio interface question Digiliz Pro Tools M-Powered (Win) 2 06-19-2006 05:09 PM
888 audio interface and mixer question wild eyed Pro Tools TDM Systems (Mac) 3 09-25-2003 07:59 PM
