Old 06-11-2007, 04:12 AM
wez wez is offline
Default apple-m \"mute region\" clash with finder apple-m \"minimize\"
i've recently upgraded to protools 7.3 on OSX 10.4. it's all good, except this is really bugging me... i can't use apple (command)-M to mute individual regions anymore, because of course it is used by the system to minimize the window. i'm guessing i might have to get my hands dirty and dive into terminal to disable it, so any advice or alternatives would be warmly welcomed.
i'm also a bit worried that i can't find anyone else here with the same problem...
anyway, it's a shortcut i use literally hundreds of times a day when i'm editing, so i really really want to be able to use it again. i'm pretty sure i can't change it in protools, and i've had no joy with the mac fora.
cheers, and thanks,
wez
Wez Prictor
The Finishing Post/Atlantis Sound
Melbourne, Australia
Old 06-11-2007, 06:10 AM
kite kite is offline
Default Re: apple-m \"mute region\" clash with finder apple-m \"minimiz
Hi Wez,
you might try disabling the "Minimise" command , using your preferences/keyboard & mouse pane, and going into "Keyboard shortcuts" selsect that shortcut , and deselect or whatever !
www.kitestudio.co.uk
Mac Pro
Snow Leopard
003 & Midas Venice desk
Mindprint DTC
Soundelux U99
Drawmer M-Clock
Old 06-11-2007, 06:59 AM
jre3132 jre3132 is offline
Default Re: apple-m \"mute region\" clash with finder apple-m \"minimize\"
it still minimizes the window with protools in front of everything? I've never seen that before.
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 06-12-2007, 05:19 AM
wez wez is offline
Hi Wez,
first thing i tried... but i've checked and double-checked, the apple-m (minimize) shortcut does not appear in the list!
absolutely. i can click on the command in the menu, but every time i try to use the shortcut, the edit window disappears into the dock. to make it even more infuriating, i've just discovered that the HD system at work is the same setup (7.3 on 10.4) and it works fine. my home system is original Mbox, PT LE 7.3.1, OSX 10.4.9, G5 1.6 Ghz.
starting to look like i have something freaky going on.
Wez Prictor
Apple+M won't mute selected regions faultyrec1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-19-2011 12:06 PM
any wabsite for apple accessories (international)& not apple.com sandman General Discussion 0 04-21-2001 06:46 AM
