Oh no! incorrect sample rate (clock prob)
Ok, I've screwed this up I know. But hopefully someone can help!
Just finished a six hour VO session only to find that my DAT machine was still set as the external sync (from a previous job). It was set at 44.1K and my VO session was at 48k. So everything sounds great - and then I turn off the DAT machine and, after saying it has lost sync, (and I get an ill feeling in my stomach) all the voices sound too high. I don't think they are playing quicker - just at a higher pitch. It'll only play properly with the DAT machine on. But if I do a bounce the voices are too high even with the DAT sync. Pitch 'n Time? if so, by how much? Anything else? A magic fix? cheers -AM |
Re: Oh no! incorrect sample rate (clock prob)
This has been adressed many times, and I seem to remember a thread a few weeks back that should not be to hard to find withe the search function
Usually this happens in studios with a central wordclock generator. good luck
Mark Haliday France, Rochefort 17300 Mixing & Mastering, Writer, Teacher Pro Tools Ultimate & Carbon M2 Max Studio |
Tough situation... I've always been told to bounce the tracks to another source and then re-record at the correct sample rate. And yes, that can be very tedious. Check that clock!
Chris
Thanks for your quick replies everyone. (I did a search first but must have missed that earlier thread)
External analog. Yep that does make sense. Might have to use a portable DAT (oh the irony!) - no sync of course... My condolences to anyone else who has had this happen. (A plug-in for this would be kinda cool) Cheers -AM |
get SOUNDHACK, you can change the file header. or create a new 48k session. import the track from the OLD BAD SESSION, and apply SRC, BUT tell, PT that the source is 44.1 and convert it to 48. then you are good to go.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Rob, yes, if they are BWF files.
Oh the joys of external clocking.
The tag data can be changed in the workspace file. You set the the sample rate to what the clock was set to, and then either have a new session at the sample rate that the external clock was set to, or apply sample rate conversion. OR Create a new session, import session data, apply sample rate conversion, and set the original sample rate, to what the external clock was set to. This will force the audio regions to be sample rate converted. I don't know how many times I've wished external clocks had a usb connector for auto switching the sample rate with PT. This would be a huge add on for the Big Ben. |
This worked great - and is MUCH quicker than capturing in analog again. Whew, am saved!
Thanks to all for ya help. -AM |
Problem detected with audio clock. Check your clock source and sample rate. | sleeptalken | Windows | 7 | 08-10-2021 01:17 PM |
Says my clock source/sample rate are incorrect, but they aren't | Csuter | Windows | 1 | 12-18-2012 07:51 PM |
Problem detected with audio clock. Check that your clock source and sample rate are c | Solow1nonly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-06-2011 08:22 PM |
Here's how to change an incorrect sample rate w. Soundhack in HD | ragbor | Pro Tools TDM Systems (Mac) | 10 | 09-16-2002 07:14 AM |
Bounced tracks have incorrect sample rate | PedMar | Pro Tools TDM Systems (Win) | 1 | 03-18-2001 02:33 PM |
