Old 02-14-2007, 07:01 PM
crazypunk184 crazypunk184 is offline
Default pro tools LE and M-Audio interface question
i just got pro tools LE, an M-audio 410 interface, and a mixer. I loaded the interface first, like it says to, and then loaded pro tools, but its still not recognizing the interface, so i cant open pro tools. im doing all of this on a pc, which i know is my 1st problem. Any suggestions or help would be GREATLY appreciated. Cheers
Old 02-14-2007, 07:29 PM
spkguitar's Avatar
Default Re: pro tools LE and M-Audio interface question
LE doesn't work with the 410. The only interfaces that LE works with are Digidesign interfaces. If you want to use Pro Tools with the 410, you need to be using MPowered.
Where/how did you get LE without an interface?
Old 02-15-2007, 10:38 AM
that was my mistake. it is the m-powered box. so it should work, correct?? its extremely frustrating. thanks for any input
Old 02-15-2007, 11:21 AM
spkguitar's Avatar
Two things:
  1. You will either need to load the drivers for the 410 from the Pro Tools disk (not the 410 installation disk), or download the latest drivers for the 410 from the M-audio website (I recommend downloading the latest drivers) This is covered quite clearly in the installation instructions in the Getting Started Guide that comes with the software. It would be a good idea to read that.
  2. You should post over in the MPowered section of this forum; you will be more likely to get answers to your questions there.
Audio Interface question tommytic Pro Tools 9 4 12-22-2011 03:38 PM
PT 9 with no audio interface question Guibara Pro Tools 9 6 12-30-2010 02:46 PM
M-audio interface question Digiliz Pro Tools M-Powered (Win) 2 06-19-2006 05:09 PM
Question about midi interface: Edirol vs. M-Audio. joesmohello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-27-2004 12:00 AM
888 audio interface and mixer question wild eyed Pro Tools TDM Systems (Mac) 3 09-25-2003 07:59 PM
