Old 08-24-2020, 01:01 AM
soundlabyrinth soundlabyrinth is offline
Default Re: PT 2020.5 Catalina Licensing Problems
Hi Tope - I am having exactly the same issue. My iLok ID is: soundlabyrinth
Is there any fix for this? I really need to use this new system ASAP.
Thanks for your help...
PT10.2.0 Native | Sibelius 7.1.2 | OSX 10.7.5 | iMAc 27" 3.4 Ghz Intel Core i7 | 8GB 1333 Mhz DDR3 RAM | Digidesign 003 | RME Fireface 400 | Lacie D2 1TB
Old 09-13-2020, 12:14 AM
Cate_C Cate_C is offline
This is my problem as well.
I've recently updated my MacBook Pro to Catalina. Pro Tools was working perfectly. Today I upgraded to the latest version = PT 2020.9.1
Now when I go to start up Pro Tools it can't see the license on my iLok.
I went to my desktop computer with Mojave and a previous version of Pro Tools and there is no problem.
I've done all the license refreshing and synchronising, and iLok Manager updating to no avail. It would be good if someone would follow up with a reason why this is happening instead of resolving the issue for a few people behind the scenes.
Old 09-29-2020, 08:43 AM
masher masher is offline
Default Re: PT 2020.9 Catalina iLOK Licensing Problems
I am experiencing a dreadful failure with iLOK at the moment. All of my previous and current licenses show on iLOK online but I cant sign in AT ALL into the licence manager. I really don't know what to do. I tried everything inc. getting some advice from colleagues here and sending a ticket to iLOK. Something must be corrupt and I do not know how to solve it.
I am very delayed with my projects.... radio you know.... happens on TIME. Avid's response is super slow. HELP
Old 09-29-2020, 09:37 AM
DigiTechSupt's Avatar
Apologies for the delay. upon checking, you still have not selected an upgrade option inside your my.avid.com/products#myproducts
Please go here and click on your Pro Tools tab, and click on select upgrade option and select the license you'd like to upgrade to the latest version to.
Thank you,
-Tope
Avid Audio Tech Support
Support FAQ
Old 09-29-2020, 09:40 AM
Hi Cate,
Upon checking, your Pro Tools Perpetual Bundle (with 10/11/12) is still activated on your iLok 2 dongle. Please deactivate this while signed in on your iLok license manager and leave Pro Tools Ultimate Perpetual Bundle (with 10/11/12+I/O) activated.
Thank you,
-Tope
Support FAQ
Old 09-29-2020, 09:46 AM
Hi, I've just checked your license and it's still not activated. Not sure why you're unable to sign in on your iLok License Manager. You can try reinstalling a fresh copy from ilok.com
If the same issue occurs, try connecting to a different ISP or server or try using a VPN. Let us know how it goes.
Thank you,
-Tope
Support FAQ
Old 10-17-2020, 06:57 PM
monkeymansound monkeymansound is offline
Hi I am having the same problem with my Pro Tools Ultimate license. Like the previous user, every time I try to open Pro Tools, I get an activation pop up, and have to log in. I then get this message:
"Select License To Activate: You don't have any licenses in your account, or none of your licenses have activations available, or their license limits will keep them from authorizing the software. If you have an iLok USB device with a license activated on it, please plug it in now. You do not have any pending deliveries for the license(s) you need to authorize the software."
I just upgraded my Mac mini i5 (2012) to Catalina. Ilok Manager sees my perpetual license. I moved my licenses to the cloud. No luck. Reinstalled PT. No luck. Basically Pro Tools thinks that I don't have a license which I do and was using it a day ago. Help!
My OS is10.15.6. My Pro Tools Ultimate version is 2020.9.1.123
Old 10-18-2020, 08:40 AM
Hi Tope and Avid Audio Support,
I have this exact problem after upgrading my i5 Mac mini 2012 to Catalina. I have tried moving my license to the cloud as well as a different iLok. Still Pro Tools fails to launch without the same message - "Select License To Activate: You don't have any licenses in your account, or none of your licenses have activations available, or their license limits will keep them from authorizing the software. If you have an iLok USB device with a license activated on it, please plug it in now. You do not have any pending deliveries for the license(s) you need to authorize the software."
Sincerely,
Paul Hackner
ilok id: phackner
Old 12-19-2020, 06:05 PM
ultrajay27 ultrajay27 is offline
I am also having this problem.
Message reads:
Select License to Activate
You don’t have any licenses in your account, or none of your licenses have activations available, or their license limits will keep them from authorizing the software. If you have an iLok USB device with a license activated on it, please plug it in now.
iLok works on my 8 core iMac, but PT can't "see it" on my other iMAC
CPU spike- Catalina / 2020.5 christianlukegates macOS 24 03-19-2021 11:39 AM
Pro Tools 2020.5/2020.3 Compatibility with Catalina 10.15.4? derrickhou macOS 4 07-26-2020 07:46 AM
Is 2020 better w Catalina? Rectifried Pro Tools 2020 13 04-06-2020 09:28 AM
Downmixer in 2020.3 (Catalina) Michael Carnes Pro Tools 2020 5 04-05-2020 04:51 PM
2020.3 Catalina video support andystar Pro Tools 2020 4 04-01-2020 11:43 AM
