Pro Tools 12.3.1 Tab To Transient Is Not Working Properly
I'm on pro tools 12.3.1 now and I have a new problem that's driving me crazy.
I just did tab to transient editing on the nose I painstakingly worked two tracks like this as I'm editing third track the same way I really expanded the grid and I see a lot of my wave forms on the other two tracks that I did tab to transient editing are off here and there I'm like are you freaking kidding me. I don't know what to do. Is there maybe a special command I have turned on that's caused this? This is so messed up. Happy Thanksgiving to you and your family
System Details |
Re: Pro Tools 12.3.1 Tab To Transient Is Not Working Properly
I used it a lot on 12.2 and it would be off (passing a transient) here and there but nothing major
Maybe 5-10 times in a 4:30 min song with over 2000 transients chopped....., All I can say is Keyboard Maestro is amazing
Never hear d of Keyboard Maestro, is this mac only? I'm a PC. How do you use it with pro tools that makes this so amazing? Curios?
System Details |
Yes Mac only....its a macro program
So I had a ton of bleed in my snare mic....that and the wood block is super loud and too close to the snare. So I chopped up the snare track, now I found this after I had done the work already but PT does have feature that chops the audio file up at the transients, the complete file, but I used KM to do that..... I recorded the macro to "tab, then CMD E, then tab", repeat 1000 times. After that I made other macros to move certain slices (if you will) to new audio tracks, then I converted audio to midi and used the midi tracks to trigger samples ...... So I did this for kick, snare and the woodblock. It came out really well and I am really happy with it. So the moral of the story is....record your drums better, but if not a macro program can save you tons of time. I also use it for tasks like, show/hide clip bins Clear all solo buttons Disable groups Etcetera, yes I am missing my control surface.....(rip pro control)
IIRC Auto Hot Key is what you need on PC.
Cheers,
Tab To Transient Missing Transients?
the tittle is self explanatory, I've been working for 4 hours now and this is getting on my nerves, it just eludes all the transients in my tracks, wonder if there is an option to make it more sensible to transients so it doesn't miss them or maybe its definitely a BUG?!!
Re: Tab To Transient Missing Transients?
what version?
Last one 12.3.1 T
Mac? PC? Are you in waveform view, and is tab to transients on (I have to ask)? Have you tried to trash PT preferences, reboot and try again?
I've been editing audio all day, and it works fine here. Details are in my signature.
Auto Hot Keys is really nice and works great...but man the learning curve is nasty.....but it's easy enough once you have the send command down.
Digidesign Midi IO not working properly in Pro Tools 11.1 HD on Maverick! | bigknowsal | Pro Tools 11 | 1 | 01-05-2014 07:39 AM |
Can't get my pro tools le 8.05 working properly | rockposer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-05-2011 12:27 PM |
Signal from Profire 2626 to pro tools isn't working properly | beasleymusic | Pro Tools M-Powered (Win) | 2 | 08-21-2010 08:09 PM |
Pro Tools M-Powered at 96khz: is it working properly? | creator | Pro Tools M-Powered (Win) | 0 | 12-01-2007 11:44 AM |
Tab To Transient not working...any ideas? | Allbaldo | Pro Tools TDM Systems (Mac) | 2 | 03-20-2006 01:56 PM |
