Old 03-18-2020, 02:37 AM
Eoin2000 Eoin2000 is offline
Default Re: New to ADAT
thanks a million for your help
Mac (Tiger - 10.4)
Digi 002
Pro Tools 7LE
JFreak's Avatar
JFreak JFreak is offline
No problem
Janne
Old 03-18-2020, 02:43 AM
JFreak's Avatar
Just always remember: a digital system may only have one Clock Master and all other digitally connected boxes need to be avle to lock to that clock. ADAT and AES dwliver clock with it but obviously only to the direction audio stream is going. That is why most pro boxes have WordClock i/o to distribute that common clock.
Because 002 does not have WC your only option is set your ADAT box be Clock Master and have 002 sync to external clock that comes in from your ADAT feed.
Not your problem right now, but just to educate you.. if you wish to use two extra channels of SPDIF you need a box that has both SPDIF in and out and connect to 002 with both cables. Like a digital reverb. When you have connected SPDIF both ways and set the external reverb box to lock to external clock (which would now come from 002 because the clock travels in the direction of audio stream) you can use that box as hardware insert.
Janne
Old 03-18-2020, 05:39 AM
EGS's Avatar
EGS EGS is offline
The U-PHORIA UMC1820 does NOT operate as an ADAT expansion module, only as a primary I/O interface. It does not offer that capability. The ADAT ports operate fine as expansion ports to the 1820, but the 1820 must be the primary I/O.
Click for audio/video demo
Click for resume
Old 03-18-2020, 05:40 AM
JFreak's Avatar
Which means both boxes need their own computer and DAW to operate
Janne
ADAT to PTMixPlus via ADAT bridge...digital pops? Phattlippz Digidesign Hardware & Software 2 05-28-2006 05:13 PM
ADAT IN works fine - but dont get Output via ADAT kaladun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-08-2005 04:15 PM
Digi001 ADAT, Alesis ADAT Edit and Fostex VM00 phobia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-24-2001 08:57 AM
PT/ADAT Bridge/Fostex ADAT/USD/Beta...... Raven Pro Tools TDM Systems (Mac) 1 12-27-2000 06:27 AM
cable lenght (fiberoptics) adat to adat bridge olek Pro Tools TDM Systems (Mac) 10 02-21-2000 07:47 PM
