Attention not changing workstation
Hello,
Having an issue on the S6 with two workstations attached; Using; Attention Most Recently Clicked DAW Area Example: Clicking on DX rig with the DX rig selected on workstations, I click in MX I get my attention fader but my workstation isn't switching. Tried all preferences. Any help would be appreciated. Thanks S6 2021.10 Pro Tools 2021.12 |
Re: Attention not changing workstation
Hi Jeff,
Tried it with this on and off still the same issue. Thanks |
For multiple workstations, I would proceed as follows:
Focus Workstation of Most Recently Attentioned Track = On. Attention From Focused DAW Only = Off Jeff |
Hi Jeff,
I have 2 S6's here, one on 2021.10 & 2020.11. I'm not seeing this issue with 2020.11 but I am seeing it on 2021.10 with the user settings you mentioned, I can confirm this is a bug with the latest S6 firmware. Thanks |
Just tested here and we are not seeing this, its working as it should. Not sure why it isn't for you. If you save out a Title(Layouts) and post a link to it we can load here and make sure the prefs are correct.
Hello,
After some further investigation we were running 2021.10.0.96 seeing this issue, now running 2021.10.1.29 and no longer seeing this. We were unaware of this small increment firmware update, I appreciate everyones time on this. Thank you |
Just bumping this as the switching WS on attention track from DAW seems to be extremely unreliable again.
Sometimes resetting WS (By taking it off and on the surface or restarting the app) helps. Sometimes building a layout with all WS tracks in helps the surface to find the information it needs to switch focus. Often, the fader will appear on the attention fader but the s6 itself doesn't flip to attention that fader's WS. WS and S6 are 2022.9.0.44 ProTools 2022.10 OS tried on both 10.5.7 and 12.6.1 Anyone experiencing similar on multi-WS setups? |
Greetings,
I haven't heard other users describing this particular issue. Feel free to send us some logs and titles and I will have engineering look at it. best, Jeff |
Attention help plz | innenhofstudios | Avid S4/S6 | 2 | 05-07-2020 06:55 AM |
Changing note values while changing meter - I'm stumped | jrmintz | Pro Tools TDM Systems (Mac) | 4 | 10-30-2011 03:55 AM |
changing tempo without changing pitch | Sharabelle | Pro Tools TDM Systems (Mac) | 3 | 02-10-2007 05:19 PM |
Changing tempo w/out changing midi performance??? | toddm7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-12-2005 10:35 AM |
changing tempo without changing midi | wizdoom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-20-2004 05:40 AM |
