Old 08-10-2020, 01:48 PM
dr sound's Avatar
dr sound dr sound is offline
Default Matchbox by The Cargo Cult
Watch this:
http://thecargocult.nz/matchbox.shtml
Brilliant!!
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 08-10-2020, 05:01 PM
Cheesehead Cheesehead is offline
Default Re: Matchbox by The Cargo Cult
I upgraded straight away.
Its a no brainer.
All Justin's software is superb!
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 08-13-2020, 12:30 AM
Branko's Avatar
Branko Branko is offline
Fantastic! Bought it immediately!
Branko Neskov c.a.s.
www.loudness-films.pt
Old 08-20-2020, 07:55 AM
Roger Stauss Roger Stauss is offline
Good morning folks. I'm trying out Match Box and may be missing a simple step:
Match Box does not "see" my tracks when I select the regions with the I beam markers.
As shown in the You Tube video seems pretty simple, but there's no wave forms in the MB windows. What obvious steps am I missing? Thank You!
Roger
Old 08-20-2020, 08:28 AM
If you can't see the audio wave form you probably have audio tracks hidden?
The blue "A" button bottom left. Or you've disabled the tracks and have those hidden (the button with the big X, bottom left)
Old 08-20-2020, 08:44 AM
Hi Frank. I did check those buttons to make sure. Here are the steps I took:
I launched Match Box.
I launched ProTools with the original mix and new mix/cut from the editor in the same session.
I highlighted the regions to be conformed and hit the "Launch Re-conform" button as shown in the You Tube video. Nothing happens.
What's the Match Box Helper plugin's role in all this?
Do I have to load sequences into Match Box manually?
Justin at MB indicated that MB will automatically load the clips to be conformed.
Thank you for the help.
Roger
Old 08-20-2020, 09:35 AM
Roger
Hi there,
I think you are misunderstanding how MB works. While it conforms your ProTools session it first needs to find out what to change by comparing the old and new sequences based on AAF, Audio, Video, EDLs. It doesn't read your PT session, it reads the data from the cutting room and finds picture and/or audio changes and then re-conforms your PT session.
I strongly recommend to watch the quick start guide video as there's too many details to explain in one response here. Also the other videos about re-conforming. There's a bit of RTFM to do if you are starting from scratch.
I guess you just have an empty MB launched (no content in OLD, NEW and MATCHES timeline inside MB)? There's no data in MB so it won't conform anything at this point so hitting the re-conform button won't do anything.
So yes you'll have to load video, or audio guide, or AAF or EDL or all of the the above to give it something to work with.
F.
Old 08-21-2020, 08:30 AM
Thank you Frank! Got it working.
Old 09-30-2020, 02:03 AM
kosmokrator kosmokrator is offline
does anyone know a way to have Matchbox compare the audio (editor's mix) of two video files without having to extract the audio first?
Old 09-30-2020, 06:44 AM
JRChappell JRChappell is offline
Good question. I couldn't figure it out. It would be nice if it was an option when importing video.
HTML code is On
The Cargo Cult - Spanner 3.0 TrentWilliams AAX Plug-ins 1 07-01-2017 11:49 AM
Spanner by thy The Cargo Cult / Maggot mpeg5 Buy & Sell 0 09-12-2016 03:59 AM
FS: Cargo Cult Spanner jmattchan Buy & Sell 0 12-22-2015 07:00 PM
Cargo Cult at AES 2015 StefB Post - Surround - Video 7 12-07-2015 08:57 PM
Introducing The Cargo Cult The Cargo Cult Post - Surround - Video 1 01-14-2015 08:52 PM
