Old 07-20-2020, 11:04 AM
mikes-music mikes-music is offline
Default Since yesterday: PT 2018.12.0 didnt find my D-Control ES?!
Hello my friends!
Since Saturday (for 2 days ago) my PT didnt find my D-Control!
It works without any problems for more than 1,5 years.
Mac-OS is Sierra 10.12.6 and I have NOT installed any updates or new drivers...
What can I do? Anyone any ideas?
Thank you and kind regards from germany!
Mike
Old 07-20-2020, 03:18 PM
Led Led is offline
Default Re: Since yesterday: PT 2018.12.0 didnt find my D-Control ES?!
What is showing in the ethernet settings in the peripherals page of the setup menu? Is the correct ethernet set in the dropdown window?
Old 07-21-2020, 01:07 AM
There is selected "Ethernet 1". That is the right Port and it works until Saturday...
Old 07-21-2020, 08:04 AM
crizdee's Avatar
crizdee crizdee is offline
I trust you have re-scanned in the peripherals ethernet port? is it showing in the etherrnet box-window at all or is nothing coming up?
Have you tried a new cable?
Are there any lights on the ethernet port on the command?
Can you check the ethernet is working on the computer? maybe plug into a hub or router and see if its working?
Re-set the command?
Chris
Producer, Engineer,
www.ukmastering.com
Old 07-21-2020, 10:02 AM
I really checked everything:
- LAN cable replaced
- LAN switch replaced
- All LEDs checked
- Re-Scan the peripheral Ethernet-Hardware in ProTools
- Checked the Ethernet-Konfiguration in PT (no changes - everythings right!)
- LAN works perfectly throughout the house
- MAC is in the LAN
- Reset D-Control
- Reinstall firmware on D-Control
But today:
I use the second Ethernet-Port from Mac! Change the PT Ethernet-Hardware on the peripheral page from "Ethernet 1" to "Ethernet 2"!!!
AND IT WORKS!
Sorry?!? Apparently my Mac swapped the two ports ?!
Thank you for help!
Kind regards
Mike
Cannot find 2018.3 eucon installer Joris de Man Avid S1, S3, Dock and Control App 6 03-29-2018 11:18 AM
2018.3 won't launch. Worked fine yesterday DontLetMeDrown Pro Tools 2018 0 03-26-2018 06:36 PM
new pt8 Mbox2 didnt find my existing plugins playmemuzk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-14-2011 03:49 PM
I Didnt get 7.2 WTF??? digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-10-2006 05:46 AM
why didnt they think of this jmallen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-11-2004 11:08 PM
