Old 06-09-2020, 01:29 AM
clancychris clancychris is offline
Default "ALL" Group keeps turning on
I keep opening sessions to find the "<ALL>" group highlighted.
Often I don't realise until I hit mute/solo on a track or try to adjust a fader. Really quite irritating.
I'm not turning this on manually either unless there's a shortcut I'm unaware of.
Just wondered if anybody else has experienced this?
Old 06-09-2020, 04:20 AM
Default Re: "ALL" Group keeps turning on
You know ! (i.e. shift-1) is a shortcut for ALL when Groups Keyboard Focus is enabled? Not that I can imagine why you'd be pressing that by accident, but still.
Old 06-09-2020, 04:54 AM
crizdee's Avatar
crizdee crizdee is offline
"Link timeline and edit selection" so when you go to the edit window its selects all tracks.
try disable them all and then see if making a selection in the edit window turns them on again. if yes then its probably this setting.
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-09-2020, 07:59 AM
philgrab philgrab is offline
I've been having this same troublesome behavior. You open the track and clik on track you want to delete, hit the delete option and suddenly all of your tracks are gone. No undo. Happens when you are moving rapidly through things.
The only recourse is to close without saving and then open the session again. It seems like this shouldn't happen or at least provide an undo.
Also happens when you go to duplicate a track and don't notice everything is selected out to the left. Suddenly you have twice the session you needed. Catches me all the time. The hand eye connection is used to focusing on the task and not having to check other parts of the interface before executing a task. It's just not intuitive.
Old 06-10-2020, 02:40 AM
I totally totally agree that it’s ridiculous that there’s no undo for “delete track” in 2020. There was probably a good reason for it back in the day but it’s just bizarre behaviour in this day and age.
Old 06-11-2020, 04:21 AM
crizdee's Avatar
"Link timeline and edit selection" when this is selected when you make a selection on the timeline it selects ALL tracks in the session, so its easy to accidently delete/duplicate all etc.
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-18-2020, 12:34 AM
Originally Posted by crizdee View Post
Chris
Thank you! I'm going to try this, you may well have saved me from gaining a few more stress related grey hairs lol.
Avid Control: "Master" is being removed from a group with VCA automation Ellis Beckwith Avid S1, S3, Dock and Control App 0 03-03-2020 11:40 AM
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
Mix Groups malfunctioning when "Link Mix/Edit Group" setting is off nruyle Pro Tools 12 14 11-26-2017 11:43 AM
turning off "External" monitor on OMNI Tim R. Pro Tools HDX & HD Native Systems (Mac) 2 06-25-2013 07:10 PM
Turning off "Record Ready" on every track Farmer Dave Pro Tools 10 9 12-14-2011 07:20 AM
