Old 02-17-2017, 02:21 PM
griff71177 griff71177 is offline
Default Worried about making the switch back to PC
So is it safe to say windows 10 pro 64 is good and stable to use with pro tools 11 (not hd version), even though the "help us help you" pro tools 11 compatibility link says windows 7 and 8, but doesn't include windows 10?
I have a 1,1 Mac Pro tower and can't go 64 bit due to the mother board not being compatible with 64 bit versions, and am making a switch to a very fast "ryzen chip" pc with 32gb of ram running windows 10 pro 64 bit. I'm nervous due to my Mac buddies telling I will have issues, but I've been reading up on windows and pro tools and it seems like it works fine for most people.
My interface is a Focusrite Safire Pro 40 that will be connected to a thunderbolt port via a firewire/thunderbolt adapter cable. I'm pretty sure if PT9 supported it, PT11 should as well...?😳😳😳
...feeling nervous about going back to PC for music...😳😳😳
Nathan
Michael Joly Mod'd Blue Mic Bluebird microphone, SPL Channel One mic pre, Focusrite Saffire Pro 40 interface, Ryzen 1700 Windows 10 Pro 64 Bit computer, Pro Tools 11, Akai MPK 49, Event TR8XL monitors
Old 02-17-2017, 03:06 PM
TOM@METRO's Avatar
Default Re: Worried about making the switch back to PC
Windows 10 here. I have run 11 on it, but not for extended periods.
Compatibility>>> http://avid.force.com/pkb/articles/e...rts&popup=true
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.10 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-17-2017, 03:31 PM
Yes, you are correct. I see the compatibility link with PT12, but I have also seen in this forum where people are running PT11 with windows 10. Has anyone on here that is running windows 10 and PT11 noticed any issues with compatibility?
Nathan
Old 02-17-2017, 04:34 PM
It runs fine. You can run all the way back to PT 8.05 on Win 10. My only thought would be possible issues with an amd based system. All development and testing anymore is Intel only (Mac and PC) It is probably fine, but that is something to remember.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 02-17-2017, 06:11 PM
Neil H Neil H is offline
I have to admit I did think "uh oh" when i read that
Just bear in mind that your buddies may be quick to blame Windows when most of the time its not the root cause of most problems users come up against.
You dont have to listen to my advice but I really would recommend skipping the AMD and go all Intel. its just too much of a gamble when you are trying to prove to yourself and your buddies that a Windows Pro Tools rig is a solid option. A known quantity of a tried and test platform will far outweigh the potential cost savings when it comes to having a dependable system.
Pro Tools 2019.5 Ultimate
Windows 10 Pro
Join the Facebook Pro Tools Windows User Group
Old 02-17-2017, 08:16 PM
Well noted thank you. I also see most using windows are running HD versions. Anyone running non-HD pro tools using windows 10? Are the non-HD versions not running well/are running well with PC's?
Nathan
Old 02-17-2017, 09:30 PM
HD and "non" HD are the same. HD has unlocked features which are licensed from the Ilok. They are the same installer, everything. Just unlocked features.
pro-tools-pc.com
Intel I7 6800k
Win 10
Old 02-17-2017, 10:01 PM
I thought it was different due to the zero latency recording and being able to record while using plugins. NON-HD pro tools has the hw/buffer, you saying pro tools HD still has that too or no?
But as far as running more stable than non-HD versions, no notable differences between the two versions on windows pc's?
Nathan
Old 02-17-2017, 10:25 PM
Also, no reason to upgrade my firewire audio interface to utilize the thunderbolt port on my soon-to-be new PC is there? Since I'm not running Protools HD and I'm not recording while running any plugins, I should still be ok with a firewire to thunderbolt adapter to connect and use my audio interface, right?
Nathan
Old 02-18-2017, 01:49 AM
Honestly, I did not think AMD boards would be capable of having Thunderbolt since it is an Intel technology. Are you sure it has Thunderbolt, and not just USB C? I have not actually looked into it, so just curious.
Your latency will be dictated by your interface drivers. It does not matter if your Firewire interface is running over Thunderbolt or a Firewire connection.
Even with PT HD or Native, the latency is dictated by the interface and drivers, not the software. You do not get better latency with HD software. The difference comes in when you start using Avid or other Digiport capable interfaces.
pro-tools-pc.com
Intel I7 6800k
Win 10
Making the switch Windows to Mac mmoranx11 Pro Tools M-Powered (Mac) 4 04-28-2009 06:42 PM
Making the switch..but should I wait? Numi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-05-2008 09:06 PM
Making the switch from PC to MAc KMAN385 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-22-2006 02:15 PM
Thinking of making the switch to MAC herbyherb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-02-2006 07:23 PM
Switch Mac Mbox to Windows - and then switch back bluesigns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-07-2004 10:50 AM
