Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 06-29-2020, 07:26 AM
mij sang mij sang is offline
Default Harmonic Foldback during bounce
When bouncing to a lower sample rate, does PT process with the higher sample rate or the lower rate that the file is going to? Is there there a setting I can change? Is this why I should print rather than bounce?
Thank You
Old 06-29-2020, 07:28 AM
JingleDjango JingleDjango is offline
Default Re: Harmonic Foldback during bounce
The sample rate conversion happens after it bounces at the session's native sample rate. If you watch the progress dialogs during bounce, you'll see a second progress bar for the SRC process after the bounce has rendered fully.
Old 06-29-2020, 09:47 AM
If I print and then convert the file to a lower sample rate, what rate would it process the conversion at? I am trying to eliminate Harmonic fold back or aliasing.
Thank You
Old 06-29-2020, 10:15 AM
Thank You
Huh? Pro Tools works internally at whatever the session sample rate is. "what rate would it process the conversion at" does not even make sense. A sample rate conversion has an input (session rate in this case) sample rate and an output sample rate, there is no other rate to process things at. (and whatever up conversion etc. plugins might do internally they will keep doing).
I am not following why you are asking this after being told the bounce happens at the current sample rate and is converted in a separate pass. Surely whatever harmonic issue you are trying to solve is going to be better processed at the (presumably) higher session sample rate then converted down... right? so why not just bounce if you want to get ouput... if you just want to work on a print... then do so... at the session rate.
Old 06-29-2020, 11:34 AM
I misunderstood the first answer I received. I responded too soon. I know that in Reaper there is a setting that you can check that allows you have your files bounced in the current sample rate or not. This is why I asked initially.
Foldback sends mirror Mix window main faders? turnyouritch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-03-2010 11:13 AM
Foldback Mix: Vocal Pitch -vs- Headphones. _Dova_ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-29-2005 09:43 PM
Setting Up PT to a Headphone Amp Foldback rcourell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-16-2005 08:07 AM
Timelag on foldback to rec room dracos ryebeard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-16-2004 10:10 AM
studio foldback in C24 cebolao ICON & C|24 1 11-05-2001 05:24 PM
