#101
Re: Pro Tools 11 Beginner
System Details |
#102
Also, my newest question: I am relatively new to Pro Tools, having a problem with my new EZdrummer software. It seemed to be "playing nice" with Pro Tools 11: I can add EZdrummer in a stereo track and the track levels read the "sound" of the drumkit. However, when I initialize the transport to actually record, I just get a "flatline" on the read out graph and, of course, nothing upon playback. What am I possibly doing wrong? Please excuse my jargon, I am pretty new to Pro Tools and computing. I will say that y'all are always a great and encouraging help. Patiently awaiting any and all feedback concerning my latest matter. Thank you in advance!
System Details |
#103
Please follow the DUC forum rules/etiquette and post once per problem/topic, You have already started another new thread for this question. Spamming questions in multiple places often ends up with a mess of uncoordinated/confusing questions and replies and just annoying other users. See my comments/questions on that other thread.
#104
Open the Pro Tools Reference Guide and do a search for the word workspace. There's a summary on page 17, and a link to the Workspace Browsers (chapter 16) in the manual.
#105
System Details |
#106
Recording, playback, and mixing going fairly well. No problem using PT11 supplied plug in "effects" while mixing. EZdrummer working fine as well, thanks to your suggestions. New problem, though: I purchased and downloaded/installed Melodyne Essential (64 bit) for tweaking my vocals. When I go to the drop down menu to utilize Melodyne as a plug in, it does not appear ANYWHERE as a selection choice. From what I can see on You Tube, etc., Melodyne should appear as a choice under "instrument". It is not there or anywhere else. I am assuming that their must be some setup option or something like that that I have failed to select properly. Totally stymied. Any suggestions from the wise folk on the front line as to what I could possibly have done (or not done)? Patiently awaiting advice and instruction,
Matthew
System Details |
#107
Melodyne if installed correctly appears under "other" and if there is anything melodyne under instruments do not use that now. Start Melodyne under Other and see. It is only Melodyne Editor 2.X that works with PT11 so Melodyne Studio 3 doesn't work in PT11 yet, update ypur Melo Editor to the latest update and then it will appear under Other in the plugin Menu. Best Christopher
#108
System Details |
#109
So .. Have you installed the update so you have latest version of that? You need to use Melodyne on an Audio Track and it should be under other. Here is a video showing that process http://www.celemony.com/cms/index.ph...deos&tab=3#top If so I would re-install and do the whole preferences, plist and dae folder delete and try again. Chris
#110
I am pretty sure that I downloaded the PT 11 compatible update, but I will double check. When I go to download, it gives me some choices. Do I want to download the 32 bit AND the 64 bit or just the 64 bit? A little unclear on that. Also, could you please elaborate on what you mean by "If so I would re-install and do the whole preferences, plist and dae folder delete and try again". I want to, if necessary, follow your instructions explicitly and get things working correctly. I am pretty new to all of this, and am unclear on some this terminology. Thanks again for your kindness and patience with a "newbie", Matthew
System Details |
Beginner questions about Pro Tools 11 | SWBoatman25 | Getting Started | 2 | 03-19-2014 10:44 AM |
Pro Tools 11 Beginner | btwnthbttns | Getting Started | 64 | 12-24-2013 04:11 PM |
Beginner Having Beginner Problems Recording | boymales | Pro Tools TDM Systems (Mac) | 4 | 10-01-2007 05:18 AM |
beginner pro tools problems | 907protools | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-25-2007 05:27 PM |
beginner on pro tools some help please | Extraaatone | Pro Tools M-Powered (Win) | 2 | 02-07-2007 09:17 AM |
