IP Audio Interface
I'm currently researching a decent, cost effective IP based Audio interface for an installation with PT12 and was wondering if anyone else had any experience. Our office is in a broadcast environment and the on air studios are already completely axia/livewire based for IP audio routing and control, and we are looking to upgrade our Production studios to comply. Other standards that i'm aware are, obviously, Dante and then also Ravenna, although I actually have no idea if either are compatible with livewire. We cannot make use of the standard interfaces provided by axia and telos as they don't fit the budget constraints for the IO they provide. An Axia xnode would almost be ideal, although the're essentially a 4x4 interface, but with no capability to mix the outputs. We need at least one virtual mixer for a headphone feed. xNodes are also overly expensive as they seem to own the market. Our production studios are fairly simple, and the most common setup is a Producer and the editor in the control room with two outputs (monitors and headphones) A mic for talk back to the voice booth. In the voice booth there is generally two mics, but can be up to six, and headphones. The voice booth headphones will need a mix of the protools output, producer mic and the voice mics. As far as out studio setup goes, required IO; -At least 8 mic inputs -At least 4 analog line outputs. -At least one virtual mixer. It seems probably far fetched as the requirements are so small and IP interfaces are generally designed to handle a lot more, but I thought i'd as ask and see if there might be some hardware that would be suitable. Cheers, Last edited by CCSCA; 03-30-2017 at 07:20 PM. |
Re: IP Audio Interface
Maybe a Hapi from Merging? http://www.merging.com/horus |
Audio is only comping from my monitor, and not my audio interface | imjtblanton | Pro Tools 11 | 6 | 10-28-2016 05:18 AM |
No audio through any audio interface - ERROR CODE "/Volumes/Development/158347/ProToo | Nikowitsch | Pro Tools 12 | 5 | 08-01-2016 09:40 PM |
M-Audio MobilePre Mk II USB Audio Interface and Mac OS El Capitan: Compatibility | mbochart | General Discussion | 1 | 10-06-2015 11:02 AM |
Upgrade from M-Audio Fast Track Pro audio interface. | lambono | General Discussion | 7 | 04-08-2013 10:05 AM |
Core Audio X: Live & PT sharing audio interface? | ashdot | Pro Tools TDM Systems (Mac) | 1 | 04-03-2003 10:59 AM |
