Outboard Reverb WHILE Tracking Vocals
Hey- I am in the middle of searching about this and wanted to see if anybody has valuable experience that I can borrow from.
When I'm tracking someone that's doing a vocal, and I'm running them directly into PT thru the Digi 001, I cannot apply effects to them (like a reverb or delay) because of the latency situation. (right?) I am thinking of grabbing a little Nanoverb or some outboard type of effects box that CAN process effects that the singer will be able to hear. Is this possible AND if so, what are you guys doing it with and HOW?? As usual, I appreciate the help if there's some wisdom to be had on this one. [img]images/icons/shocked.gif[/img] [img]images/icons/shocked.gif[/img] [img]images/icons/grin.gif[/img]
Mac Pro running OSX 10.5.6, using Pro Tools LE 7.4.2/Digi 003/Digi C24 w-DV Toolkit 2, a pair of Avalon 737 VT-737sp's, Great River MP-2NV, RME OctaMic II, pair of Mackie HR-824's, my best mics? a Neumann U87 and a Royer R-121 . . . best amps? Bogner Ecstasy 101B and a Bogner Uberschall-Revision Blue . . . All my drums are BFD2 triggered by Roland TD-20s kit, with live Zildjian cymbals, Korg Triton LE 88 with weighted keys . . . lots of other toys that make beautiful music . . . |
Re: Outboard Reverb WHILE Tracking Vocals
Just get a small mixer, any cheap one will do for monitoring, combined with reverb.
Mixers still have their uses [img]images/icons/cool.gif[/img] John K London N19 |
What I usually do is, creat an "aux input", set the input be your Mic pre, then you can insert plug in or out board effect on it when live track from this channel, but you won't get effects when you play back your record (of coz you don't need to listen to the effect when you want to check out what you recorded)
of coz. you need an audio track for recording
King Kong |
I think that will work . . . now I just gotta get an effects box!!! Hmmmmmmm- I'm not completely sure what he said.
Yup. I do it just like that. Cheap reverb on a boards aux send. It's just enough to give the singer what they need.
Chris |
I track vocals all the time in PTLE while using the Dverb supplied by Digi. Depending on your computer, you should be able to keep the hardware buffer at 128 or 256 samples and should experience practically no noticeable latency in the typical mixes. Try that before you go buy an outboard reverb. I got rid of my outboard reverb gear with the exception of the reverm in my digital mixer (which I hardly ever use).
I'll have to check that "buffer" thing . . . . I've tried this a few different ways and always end up reverb-less.
I was under the impression that I either have "latency" ON or OFF . . . I wasn't aware that there are degrees of it available.
It don't mean a thing if it ain't got that swing. |
Sounds nice, where can I have a look of the Rocktron Intellifex?
King Kong |
Tracking Vocals | Numi | Tips & Tricks | 11 | 01-18-2010 04:11 PM |
Tracking Vocals with Reverb in Low Latency Mode? | micline | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-02-2010 05:36 PM |
Singers Want Reverb While Tracking Vocals... | John J. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 10-10-2006 08:38 AM |
Outboard compressor at tracking? | Aussie169 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-10-2001 03:14 PM |
Tracking vocals (again) | Arno Peeters | Tips & Tricks | 10 | 10-18-2000 02:18 PM |
