Old 11-30-2009, 05:24 AM
ctyelvis ctyelvis is offline
Default TDIF question?
Is the Tascam TDIF connector format, the same as used by the DB-25 type connectors on the back of an 96i/o or 192i/o?
Thanks!
-Chris
Old 11-30-2009, 05:42 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: TDIF question?
Thanks!
-Chris
Yes its a standard DB25 way D connector. 99% sure tascam and Digi snakes are the same. 25 pin to pin. exactly the same connections both ends.
What will you be connecting it to?
Producer, Engineer,
www.ukmastering.com
Old 11-30-2009, 05:55 AM
Thanks for the info!
I have an old Tascam DM-24 I was thinking about hooking up to a 96i/o.
Old 11-30-2009, 06:00 AM
derF derF is offline
Analog is the same if you have analog cables. Digital will be the same if your connecting TDIF to TDIF. It won't work any other way. The TDIF format is not the same as AES. It has a different pin out from both AES and analog.
Hope this helps
Old 11-30-2009, 06:02 AM
Man...
I was hoping I could use a couple of DB-25 to 1/4" balanced snakes I had here at the house with the DM-24's TDIF. But no? TDIF is a different format than analog?
Old 11-30-2009, 06:31 AM
LukeHoward LukeHoward is offline
Man...
TDIF is a digital format.
https://lukehoward.com/
Old 11-30-2009, 06:51 AM
crizdee's Avatar
Man...
192 has TDIF so could get 8 (or 16 with the digital option card) if you had a 192
also you could use adat digital and both the 192 and the 96 has adat inputs and the dm24 has adat out for 8 channels
Producer, Engineer,
www.ukmastering.com
Old 11-30-2009, 07:05 AM
Got it!
Thanks for the help guys!
-Chris
Old 11-30-2009, 07:15 AM
formfunction formfunction is offline
Man...
From your friends at WIKI...
The Tascam Digital Interface (TDIF) is a proprietary format connector defined by TASCAM that is unbalanced and uses a 25-pin D-sub cable to transmit and/or receive up to eight channels of digital audio between compatible devices. Unlike the ADAT lightpipe connection, TDIF uses a bidirectional connection, meaning that only one cable is required to connect the eight ins and outs of one device or another.
DA88 TDIF Out to 192 TDIF IN Mixing Madness Pro Tools TDM Systems (Mac) 2 11-07-2011 09:31 PM
TDIF to MADI Question Scott Fahy VENUE Live Sound Systems 6 01-01-2011 09:30 AM
HD2, TDIF, and DA-88 Karl Kalbaugh Post - Surround - Video 4 05-23-2005 11:27 AM
TDIF SYNC I/O clock question jimlongo Post - Surround - Video 0 01-25-2005 02:27 PM
192 I/O to Dsm71 Tdif cable question SurroundNewbie Post - Surround - Video 3 02-18-2004 09:43 AM
