Old 01-12-2008, 05:59 PM
studiokeyz studiokeyz is offline
Default mono/stereo question
I finally got my new setup going, using both the s/pdif ports. Strings/piano need 2 be stereo, could I just record a mono track and dupicate and pan it the opposite way 2 get that stereo ambience, or do I need 2 inputs going into the digi002? I'm using the 2 input method now but would like 2 use that extra input for another instrument if I can just copy a mono track 2 make it stereo.
Old 01-12-2008, 06:13 PM
Craig F Craig F is offline
Default Re: mono/stereo question
you could but all your really doing is making mono
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 01-12-2008, 06:56 PM
basslik's Avatar
basslik basslik is offline
make a stereo pair, that way you have a true stereo tracks
MAC PRO 2010 5,1 3.46hex 96ram - Mt. Lion 10.8.5 - PT 9.O.6 003 CONSOLE /DIGIMAX FS /PCM90 2CHANNEL SPDIF
Old 01-13-2008, 03:43 AM
The Dougfather The Dougfather is offline
If you want stereo ambience you might consider creating a send to a stereo aux loaded with a reverb plug.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 01-13-2008, 08:12 AM
Thanks. I will create a send 2 a stereo aux. That way I can use the extra line for a lead guiar
Old 01-13-2008, 01:25 PM
flommer flommer is offline
Just want to point out that " Strings/piano need 2 be stereo" is a subjective artistic choice, not a rule.
A book I used to have called the Mixing Engineers Handbook had lots of advice, but 1 of the things that stuck was that the stereo output from keyboards/sound modules/synths etc. ended up sounding boring if it is all recorded in hard L/R stereo. Often, the sound sample being used is just being treated with some low quality built in effect (chorus,reverb, whatever) to achieve "stereo". You leave yourself more mixing options by having a bunch of mono tracks instead of stereo tracks, not to mention you are saving available track usage.
Imagine trying to present the sound of a string quartet to a user that is standing pretty close to the action. If you had 4 stereo tracks then you wouldn't be able to distinguish where the individual instruments are in the stereo field. With mono tracks you can pan then appropriately and then use a send on each track going to a stereo reverb to tie them all back together in a simulated room/space.
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
mono / stereo question shambles Pro Tools 9 21 03-19-2011 08:12 AM
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-14-2010 09:01 AM
Stereo and Mono question Daubian Post - Surround - Video 2 03-15-2007 09:08 PM
Stereo/mono question totemspock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-25-2005 08:28 PM
