Old 02-02-2009, 12:01 PM
mpeddle mpeddle is offline
Default Midi Notes cutting off when recorded
I'm running Pro Tools 8 on a MacBook Pro w/ an Axiom 49 keyboard. I also use Reason 4 (which works fine!).
When I hook up a midi instrument in pro tools, i can hear the sound in my headphones. But, when I record myself, the playback is uniformly cut off as if each note were played staccato. Conversely, when I record with the exact same setup in Reason's sequencer, the playback is totally normal.
What would cause the notes to get clipped in pro tools? Here is a screenshot of the clipped off notes :
http://img.skitch.com/20090129-fs5ih...93bp3wfpn3.jpg
As you can see, the front of each note has been chopped off.
Thoughts, anyone?
Old 02-02-2009, 12:45 PM
Default Re: Midi Notes cutting off when recorded
To be clear:
I have already run through a number of troubleshooting steps, including...
*Delete/regenerate digidesign databases
*Pro Tools 8 cs1 update
*Reinstalling software for Axiom 49
Old 02-02-2009, 10:44 PM
matta matta is offline
This may help you:
It is known issue and Russ from AVI made a short video explaining the work around.
Report back if it solves your issues.
Matt
Old 05-22-2015, 02:05 PM
Michael_Knight Michael_Knight is offline
Default Thanks
A few years late but I've had this problem. I finally decided to fix it and this post is what did it for me!
Playing Reason with recorded midi notes jamescampagnola Pro Tools 10 1 11-26-2012 12:35 PM
Midi notes cutting out when triggering plug-ins from Pro Tools/sequencing on MPC Refresh Pro Tools TDM Systems (Mac) 7 04-11-2012 05:56 PM
Cutting tails of midi notes Pieterrr macOS 12 03-01-2012 02:31 AM
Innacurate Recorded Midi notes in Pro Tools 7.3 e-rase 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-06-2007 11:57 PM
MIDI Playback notes cutting out filosofem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-22-2005 09:06 PM
