Eleven Rack power over midi mod.
I am running my eleven Rack with a Behringer FCB1010 foot controller. Got tired of too many damn cables so I went and modded the FCB1010 so it runs off of 12vDC from the spare midi pins on the midi out (No more AC power cord needed for the FCB!).
I went to the trouble of building a midi power injector cable (using a plug in wall "wart" spliced to a midi cable near the back of the 11R) and then I wondered what the 11r was using internally as a power supply. It's long out of warranty so I cracked it open and took a voltmeter to it. It turns out it runs internally on 12VDC!!! So I shelved the power injector cable idea and just ran a couple of leads from the internal power supply to the spare midi pins inside the 11r. Now when I power up the 11r it also powers and communicates with the FCB1010 over a standard midi cable! Here is the FCB1010 mod that I used--it works great! Plus you can still use the AC power cord if you wish. It automatically switches to whichever power source is plugged in. http://www.voes.be/fcb1010/pdf/fcb10...%20adaptor.pdf The 11R side of the mod was even easier, no components needed, just a couple of wires. I can post some pix if anybody cares. |
Re: Eleven Rack power over midi mod.
Great job!!!
I will finish assembling the midi footcontroller I developped for 11R and will post some pics soon. |
Eleven Rack with a power amp setup | YYR123 | Eleven Rack | 10 | 01-28-2014 01:40 PM |
Eleven Rack Power Plug | Jemini | Eleven Rack | 8 | 11-10-2012 03:46 PM |
Eleven Rack through Stereo Power Amp | brewboy73 | Eleven Rack | 45 | 07-31-2012 04:35 PM |
Eleven Rack Freeze At Power On 8-0 | brianiac5150 | Eleven Rack | 3 | 11-05-2011 09:48 PM |
Eleven Rack with Power Amp Volume | killdozer | Eleven Rack | 7 | 02-19-2011 03:45 PM |
