Old 05-30-2018, 11:10 PM
alonper alonper is offline
Default HDX on MacPro5.1 Westmere,Xeon W3690, PT12.8.3 HD?
Hello Experts!
We will be glad to get your help.
Currently, we are running PT10 HD on Mac Pro 4.1, Nahlem, 16GB 1033Mhz using 2 PCIe cards with 3 IOs. There are a lot of reasons why upgrading our PT, some of them are because of bugs and really slow flow.
So we bought HDX system, 1 PCIe and two IOs, and new PT12 license.
We found that our old Mac isn't good for the HDX hardware (and PT12 HD) and we must buy a new hardware.
So, before buying a new Mac Pro, I would like to get your advice regarding this Mac :
Mac Pro 5.1 Westmere, 3.46Ghz (W3690), 32GB DDR1333Mhz, 480SSD PCIe.
we will install High Sierra, But we've got to be sure that this Mac is good for the HDX system and PT12.8.3 and even for the PT2018...
Thanks in advance,
Alon
Old 05-31-2018, 12:44 PM
Chief Technician's Avatar
Chief Technician Chief Technician is offline
Post Re: HDX on MacPro5.1 Westmere,Xeon W3690, PT12.8.3 HD?
That processor speed is not constant, unless this is a modified Mac Pro. The fastest, continuous processor speed for that model was 3.33GHz.
Why does your MacPro4,1 not work for HDX? I understand that it may be a bit sluggish, though I have users with 2.93GHz MacPro4,1 with HDX (1 card) and two I/Os that are able to work without incident. One person I used to work with complained about a 4,1 being sluggish when I upgraded him to PT12.3.1 and OS X Mavericks.
The 5,1 can run High Sierra. Whether or not it will run PT2018 on High Sierra in a way that you deem acceptable is another matter. I haven't tried that combination yet.
The one thing you want to look out for on any Mac Pro tower is the RAM configuration. The 4,1 and 5,1 use triple-channel memory. This means that you get maximum performance with 6 RAM chips installed, not the maximum of 8 RAM chips.
Also, I have seen the ATI HD5770 on 5,1 towers fail. Its not a definitive failure either. Sometimes the computer would work for minutes, other times for hours, and then BAM! Instant restart. This is a sign that the ATI HD5770 graphics card is failing. I spent several days tracking that down. Don't trust Apple Hardware Test to catch it either. I had to swap out the ATI HD5770 graphics card to confirm that it was at fault.
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
Old 05-31-2018, 01:27 PM
Fidelis Fidelis is offline
Default Re: HDX on MacPro5.1 Westmere,Xeon W3690, PT12.8.3 HD?
A lot of us here upgraded our Mac Pro 4.1 to 5.1 via firmware and upgraded its processors to newer and faster ones. There are some topics here about that. I did it and my Mac Pro is flying with HDX. I also upgraded the video card. Very happy with it.
http://www.ricardomosca.com
Intel Mac Pro 12 core 3.33 GHz, 20GB RAM, OSX 10.10.5, PT HDX, PT 12.8, SSL 4040G+, tons of outboard
Mac Book Pro 2.4Ghz Duo, 4GB RAM, OSX 10.10.5, PT Vanilla 12.8
Old 05-31-2018, 06:07 PM
Extreme Mixing Extreme Mixing is offline
Yes. Upgrading the tower Macs is a very viable option these days. Costs about $1K. If you have a spare slot, you can get a USB 3 card, which you will love.
Steve
Steve Shepherd
Extreme Mixing
Old 06-04-2018, 06:27 PM
Samanthas Dream Samanthas Dream is offline
Upgrade your Mac immediately!!!!!
15 years as PTHD User, Protools 2018 Ultimate, 24 Channel iCon D-Command, Avid Omni, Lynx Aurora 16, (2) BLA Modified 192 I/O’s, DigiPre, Way Too Many Outboard Compressors/EQ’s/ETC, where did all my money go????
Old 06-06-2018, 07:36 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Video Cards and SSD's in 5,1 mac solid here in HS OS / HDX
(Help us Help You)<<<click here
Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in)
Pro Tools U-2019.6 MacOS 10.14.6
Second boot-10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MacVCEdition, 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDI over IP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
Old 06-15-2018, 11:07 AM
off the wall's Avatar
Hello Experts!
Thanks in advance,
Alon
I'm running Pro Tools 2018.4 on an upgraded 12 core 3.46 2010 Mac Pro. No complaints.
File Type: png Screen Shot 2018-06-15 at 2.05.24 PM.png (27.7 KB, 0 views)
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, AMD 7970 GPU, SSD boot drive on 6Gb/sec PCIe card, 36GB RAM, MacOS 10.14.5.
Pro Tools Ultimate 2019.6. HDX, UA Octo PCIe cards, HD I/O, C|24 control surface.
Mostly Avid, Waves, Sonnex and UAD Plug-ins
Old 06-21-2018, 01:30 PM
s.d. finley s.d. finley is offline
which video card did you update to? I have a 4.1 that was flashed to a 5.1, runs pretty good with a SATA3 PCIe accelerator.
sdf
sugarhillstudios.com
Old 06-21-2018, 01:56 PM
You should not need to change your Video Card unless you buy new monitors that require a new/more powerful video card. After I updated my 2009 8 core to a 12 core, I was running twin 27 inch monitors for my DAW, and my existing video card handle that no problem. I then switched to two 34 inch ultra widescreen monitors, and to get the resolution I needed, required a video card upgrade. That would’ve happened, regardless of the CPU upgrade.
Old 06-25-2018, 06:11 AM
Hi, it's a GTX 970 flashed for mac. I just upgraded because the original one was behaving strangely and I was afraid that it would break anytime. But, its was not easy because it needs two power connections and one it is used for the HDX... so I had to built a split power cable to connect both the HDX and the video card. Now it works like a charm.
Mid 2012 MacPro5.1 6core 3.33 for PT12 ? SD70 Pro Tools 12 2 05-21-2018 04:04 AM
Hp dual xeon cpu with pt12 JSOM Pro Tools 12 4 02-10-2017 01:02 PM
Mac Pro Westmere Mid 2010 drums77 Pro Tools HDX & HD Native Systems (Mac) 17 08-28-2016 10:59 AM
6 or 12 core Westmere for HDX and PT12? wilkinswp Pro Tools HDX & HD Native Systems (Mac) 5 08-14-2016 07:16 PM
Anyone using a Westmere Mac Pro...? Jon_Atkinson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 11-10-2010 07:10 AM
