Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 09-15-2017, 04:55 PM
Wcutta Wcutta is offline
Default HD Native card in PCIe x1 slot?
My computers alittle old at this point but if I don't have to do a new build I won't. I'm wondering if the HD Native card will operate as expected in a pcie x1 slot
Old 09-15-2017, 06:33 PM
panamajack's Avatar
panamajack panamajack is offline
Default Re: HD Native card in PCIe x1 slot?
The HD|Native card is a PCIe x4. I use mine in Mac Pro which has (2) x16 and (2) x4 slots.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
Old 09-15-2017, 07:49 PM
The HD Native card is a physical x4 card, but is actually only a x1 (single lane) card. It will work in any slot you can fit it in.
Old 09-16-2017, 08:28 AM
panamajack's Avatar
The user manual states on page 13:
Installing Pro Tools|HD Native Card in a Mac Pro
The Pro Tools|HD Native card is a 4x PCIe card. For optimum performance, install the Pro Tools|HD Native card in a 4x or higher PCIe card slot in your computer.
and on page 15:
Installing Pro Tools|HD Native Card in a Windows Computer
Additionally, there are different firmware versions for the HD Native card depending on which version of Pro Tools is loaded. Below is a link describing potential problems:
http://avid.force.com/pkb/articles/e...rue&popup=true
My Native card is firmware 1.05. I am running PT HD 12.4. The link above discusses issues with certain vintages of Mac and PC setups.
The reference materials were written a while ago, maybe circa PT HD 9. Considering the history of other bugaboos, I assume the choice of PCIe slot, not to mention the computer hardware and OS, may have either a negative or positive effect on PT's performance.
Old 09-16-2017, 03:50 PM
Hmmmm conflicting answers. Well even if it is x4 card would it still operate in a x1 slot maybe at a lower bandwidth? I mainly just want to use an omni for the better conversion
Old 09-16-2017, 04:19 PM
Again, it is not a x4 electrical card, it is a x1 electrical card. Your bandwidth question has no meaning. The card operates at the same x1 PCIe (1.0) speed in any physical slot. if this is not clear, go read about PCIe on Wikipedia.
They are not conflicting answers here. They are all perfectly consistent as long as you correctly understand if physical or electrical specs are being used. This includes what I wrote and the quotes from the Avid documentation. Unfortunately that doc does not differentiate between electrical and physical specs.... and they mean physical slots, a nice, but ultimately flawed, attempt to simplify documentation.
Your question and every other post in this thread fails to clarify the most basic thing... so to ask the bleeding obvious... are you talking about a x1 physical or x1 electrical slot?
And again... the Native card is a x4 physical form factor card that is electrically a x1 card. It will work in any slot it can fit in... because a x4 or x8 of x16 slot in which it fits will notionally be able to provide at least x1 PCIe lane...
So you want to actually clarify what you are asking?
If you want to shove a x4 physical card into x1 physical slot.... uh surprise... it won't fit. There are expansion cards/adapters you could use, but by that point you are hammering the wrong screw in with the wrong hammer.
Old 09-16-2017, 04:36 PM
There are any number of USB or other interfaces that have as good or better conversion than an Omni. And with potentially lower cost of ownership (no HD and DigiLink tax required) and/or much more than the 8x6 IO limits of an Omni.
If you said you wanted compatibility with other HD systems, or DigiLink expansion beyond 32x32 IO then sure. But wanting an Omni for it's audio quality seems a weaker argument.
Old 09-16-2017, 04:51 PM
Physical is what I was asking. I have open x1 slots so I from what I gather it won't fit. Now what are these others interfaces with better conversion? Firewire or usb 2 since usb 3 would require a new build and if I can I'd like to avoid that
Old 09-16-2017, 05:05 PM
No it will not fit. (some x1 slot connectors are notched on the connector so they could physically take longer cards... but there is no guarantee that will work and the card won't be properly supported even if it still fit in).
You are on a PC. So Apogee Interfaces are not an option.
If you have a PCIe x1 slot available then a Firewire 800 or USB 3 interface should all be options.
If you are running Firewire 400 today from another PCIe slot then replacing that card with Firewire 800 is also an option, but Firewire is ancientware that I would rather avoid.
We don't know what interface capabilities you really need, but I would look at UAD, MOTU, RME, or higher end Focusright stuff, etc. Got a healthy budget... Look at Prism. There is a huge number of good products out there. Personally I would be looking at Thunderbolt interfaces, but that would require a PC replacement.
Old 09-16-2017, 05:46 PM
I'm currently running an mbox 3 pro. The firewire port is built in the board. Not sure if it's 400 or 800 though. Don't really need too many inputs or outputs cause I usually record only vocals and mix in stereo.
Apogee is out unless I want the avid quartet which Im sure the Omni slays on conversion. Uad is out because I don't think their box works if the usb 3 isnt built into the board. I'll take a look at the others offerings though. There has to be a worthy upgrade out there
Trade hd native PCIe card for hd native thunderbolt card and cash? Brandonx1 Buy & Sell 8 03-22-2015 01:45 AM
Can the HDX card go in a 4 lane PCIe slot? PeterB Pro Tools HDX & HD Native Systems (Mac) 0 01-09-2014 05:11 AM
HD Native PCIe card--which slot bakedbeansrecord Pro Tools HDX & HD Native Systems (Mac) 4 11-29-2013 06:52 AM
HD native pcie slot number? vin7 Pro Tools HDX & HD Native Systems (Win) 4 05-18-2013 08:57 AM
HDX card in PCIe slot 4 agrizzlybear Pro Tools HDX & HD Native Systems (Mac) 1 05-05-2012 10:52 PM
