#71
Re: TDM Plug In Distortion compared to RTAS
Daniel |
#72
#73
Hello all,
Thank you for the honest debate and participation in this thread. Sorry to be so slow, but since many of you have called for an official Digi response I thought I’d better chime in! First, let me say that we are aware of the issue with TDM bus being 24-bit and are considering ways to address it with our future products. That said, most people can work comfortably within the confines of the TDM bus (with the notable exception of some mastering engineers who are required to work at the uppermost limits of headroom). You do have to pay closer attention to gain structure than you would with a floating point system, but hopefully headroom isn’t the only important thing to your work and the other benefits of Pro Tools HD make it one of the best sounding platforms to work on. With each new version of hardware and software, we strive to make improvements to Pro Tools and address the many different needs of our customers and issues like this (our architecture) are a high priority for us. It's an endless list, but your input helps us determine the order of what gets done, so I encourage you to keep giving us your constructive criticism. There are several ways to address the headroom issue but, as I’m sure you can understand, I can’t give you specific information on how or when we’ll be able to address it. Thanks for listening and giving us your candid feedback. Best regards, Gannon Kashiwa Professional Products Market Manager Digidesign |
#74
Hi Matt
Interesting discussion... Just a thought you might want to consider, on the 32 bit floating format the first bit, is the sign magnitude bit (one=negative, zero=positive or zero), followed by an eight bit exponent and then followed by 23 bits of a normalized two’s complement fractional part of the mantissa. Other formats might invert the position of fraction and exponent. The fact that you are able to represent huge and the tiniest of numbers doesn't mean you are able to represent all of them. border conditions render interesting situations where the format is pushed to the limit and undesirable things start to happen, and you have those conditions on the zero crossing of a signal... thanks |
#75
Will the new 7.4 address this problem? Or, is it more of a hardware thing? I can't see it being a hardware thing but more a software problem as seeing that Pro Tools HD would benifet if it was 48bit throughout instead of after every plugin it's dithered down to 24bits. Am'I correct in thinking this? So PTHD could still use the 192i/o but soon as the audio hits the software it would up it to 48bit internally throughout until the last plugin on the Master Fader which would bring it down to 24bit. Wouldn't that fix the problem and end all this? If so, why hasn't this just been done? Do we need better or more powerful HD cards? Hey, maybe just take up more slots. Is this correct thinking? M2E
New System: Macbook Pro M1 Max/16 gigs of Ram/Monterey/3 UAD Quad Satellites/2 PCIe Quad UAD cards/Waves Digigrid/Antelope Zen Pro/OWC 3 Slot Thunderbolt PCIe unit/Over 1400 plugins (Beta Tester for 15 different companies) YouTube Channel https://www.youtube.com/watch?v=HaZYp2wNomc |
#76
I mean, for mixing, there's no reason to do that. Whatever you record is limited to about 120dB dynamics, or whatever your converters can handle. That's the best case theoretical scenario and real-world signals are usually less dynamic than that. So there is already at least 24dB headroom before full scale for this theoretical and very dynamic signal. Usually that kind of signal gets compressed, which will give you even more headroom after the compressor plug, due to the very nature of compression. Now if one thinks about this for a second, it is easy to understand that if the signal requires -say- 120dB and the plugins has 144dB to use, then it is not necessary to use the upper 120dB of the plugin "workroom" but it is perfectly okay to stay on the lower 120dB and as long as you have those 120dB it's all right. The problem comes when the mixing engineer thinks that the stuff sounds better when the signal is "almost clipping". Sure, louder tends to sound better, but that's why there's master fader or monitor volume control! You can always monitor louder if you need the volume level, that is a bad excuse for boosting signal level within a plugin. In most cases it is more beneficial to lower volume or cut something instead of boosting everything you can. After all, mixing is all about balance. It is a whole lot easier to get a good balance *below* the problematic 0dBFS than trying to hit it all the time. Just get the mix done and send it to mastering (or try to do it yourself if you want to) for getting the desired level. Also... I don't mind if the next generation Protools has bigger this or larger that. It is always a good thing to have more headroom. It's just that IMO current systems have *enough* everything and it's always up to the operator how to use it.
#77
Well, part of the reason I'am wondering this is because I use the Waves SSL G-Buss Compressor and love it. They mention that the more you push level in it the more you get that SSL sound out of it. They also mention that yes, it's ok to clip the plugin....WHAT!!!!!!!!!!! Well, I've been trying it and yes, it does give you that warm as fuzzy feeling inside like the SSL but, what about that strong signal coming out of the plugin and back to the 24bit Master Fader? Something just isn't right here, is it? Also, when they fix it, before they do, did they not know about this before releaseing HD? The system is based off of plugins, right? Really weird.... M2E
#78
This is the difference between pro tools digital mixing and SSL digital mixing, and why I would never buy an Icon, but I'm close to buying one of these:
http://www.solid-state-logic.com/music/c200.html You cannot peak it. Without getting deep into the technical, the console is entirely floating point except on it's hardware outputs. You can mix 12 hot drum signals together, with tons of EQ boost, and you will never peak. There is something like 900 db of headroom when combining signals together. Really you have to talk to an SSL rep about this, but it is pretty incredible. Digi's technical white paper is a joke. While being "accurate," it leaves out a lot. |
#79
Little help here.... M2E
#80
The SSL C200 is around $350,000, completely dependent on your configuration. Yes, it is more expensive. Obviously. But between the dramatically better mixing engine, the amazing eq and compression, and the far far better tactile control surface... it really seems worth the money. Oh, and it doesn't crash. Ever. Imagine that.
The C200 has something like 900 db of headroom in the mix engine. Nothing like Pro Tools. |
adding plug-in//distortion plug-in?? | violent vickie | Pro Tools M-Powered (Mac) | 2 | 12-16-2010 12:50 PM |
RTAS Instruments CPU hungry compared to VST ? | phobia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-23-2005 06:49 AM |
Distortion plug-in | Liam M | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 09-05-2004 11:50 PM |
Distortion RTAS/plugin | po11utionX | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 04-02-2004 10:49 AM |
does anyone know of a good distortion plug in for rtas? | last115 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-12-2002 03:08 PM |
