Old 10-29-2008, 09:25 AM
wooferbitch wooferbitch is offline
Default Express Card Esata issues with MBP
I am running a MacbookPro with 4gigs ram. Protools LE with MBOX mini. This system is for fx editing on Pro Tools. I use Logic on this sytem as well as Final Cut Studio.
I have the sonnet Esata ExpressCard going to two 1 TB drives in a tower, the MBOX mini in the USB port. I use an external FW drive in the FW port when I am ready to save the session for transport to the post mixing studio. When I "Save Copy In" ( targeted to the FW drive ) the session saves and most of the time the machine crashes at the last minute.
I know the esata Expresscard setup isn't supported by Digi..but I have had no trouble running at least 24 tracks with a lot of edits.
Has anyone had similar issues ?
as a side note..I feel with everything plugged into all available ports, that the MacbookPro doesn't have enough juice to support all of the devices.
When I added an extrenal Monitor to the mix, wether I was running Pro Tools or Logic I would get massive shutdowns.
I run Final Cut Studio pulling HDV and DV off the Esata bus and have no issues when using the Apogee DUET, but when I run Final Cut Studio through the Mbox mini I crash quite often, especially when scrubbing.
frustrating.
Old 12-13-2008, 09:48 PM
Maddawg383 Maddawg383 is offline
Default Re: Express Card Esata issues with MBP
i'm haveing that problem right now with the siig esata card.
my system is crashing during recording at around 26-27 minutes every time.
did you ever solve your problem?
Old 12-14-2008, 07:05 AM
JrummerJ JrummerJ is offline
I have a Macbook Pro (2.2 GHz Santa Rosa, 4GB RAM, 128MB video card) and I use both an external monitor as well as an espresscard. However, my expresscard is the siig fw400 card on which I connect my (non certified) WD MyBook external drive.
I am running Leopard (10.5.4) with PTs 7.4.2 and it is very solid. I would guess that there is something going on with the esata card, though I hadn't heard of that problem before. Why not just try the 400 card? I really don't think that should bottleneck and cause much of a reduced track count or anything. When I was having some issues, I spoke with Sweetwater's Digi Technician and he said that he runs a test session for troubleshooting purposes with 32 tracks and tons of plugs on the same laptop as mine, with an Mbox 2 Pro and a Glyph drive.
J
Old 12-14-2008, 02:30 PM
Useing a FireWire expresscard will be my next test.
To see if its the esata card or the slot.
Belkin upgrades Thunderbolt Express Dock to include Esata, USB 3.0 nst7 Pro Tools 10 1 06-05-2012 08:37 AM
MBP Express 34 dual eSATA card 2 recommend? aka21stCentury Storage Subsystems 10 11-11-2011 06:02 AM
eSATA card for macbook pro therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-07-2008 12:57 PM
Recommended Macbook Pro eSATA Express card? Tbassist4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-24-2008 05:05 AM
eSata card and drives in G5? subwoof Pro Tools TDM Systems (Mac) 1 08-07-2006 05:18 PM
