Old 04-30-2022, 02:51 PM
Swapski Swapski is offline
Default Protools not seeing more than 1 Drumpad.
Hello everyone,
I have 2 Kat KTMP1 drum pads but only one works at a time if I shut the first one off the second one works, If I shut off the second one the first one works
in the midi instruments drop down it will only show 1 Pad at a time. If i run them in superion drummer as a standalone they work fine. I even tried a different Daw interface .. same result
I and running PC and windows 11
I have hopes someone can help me
Protools not seeing more than 1 Drumpad. Swapski Pro Tools 2019 0 04-30-2022 02:56 PM
Protools 12 - Input Audio Window Keeps on opening Protools Cache soundman1234 Windows 0 08-25-2016 11:27 AM
ProTools Shortcut keys suddenly became disabled in ProTools LE 8.0.5? jgbsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-03-2011 01:08 AM
converting an electronic drumpad to midi? Ken P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-09-2006 05:38 PM
setting record levels into ProTools with the intent of mixing in ProTools Felix Tips & Tricks 507 02-05-2002 10:17 PM
