Old 11-17-2018, 02:11 AM
GuidoHelbling GuidoHelbling is offline
Default Soundminer V5 Pro Preview
Soundminer Version 5 Pro has just been released as a beta version for testing.
Reason enough, then, to take a closer look at the latest version of Soundminer and prepare an article.
If you would like to get a taste of the updated Soundminer V5 Pro yourself, you can do so here.
Please note that you will need a valid Soundminer V4.5 Pro licence for testing.
Pro Tools Ultimate 2019.10.0 with Dante, MacPro 12 Core, 32 GB RAM, OS 10.13.6, Dynaudio bm5a mk2 and 7.1.4 Dolby Atmos Monitoring
https://www.avosound.com/en/
https://www.guidohelbling.com/
Old 11-18-2018, 03:51 AM
Cheesehead Cheesehead is offline
Default Re: Soundminer V5 Pro Preview
Oooh exciting!
Thanks Guido.
Mac Pro 6,1 12 core, OSX 10.14.6, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, PT Dock, PT Control, PT 2020.5
Old 11-18-2018, 05:03 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Originally Posted by Cheesehead View Post
Oooh exciting!
Thanks Guido.
No more support for my older SD2 files. Need to do a massive batch transcode to WAVE. I still consider what would be the best way for doing so without keeping the old SD2 files but maintaining the newer WAVES in original folders they belong to.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2020.9 Ultimate ● macOS High Sierra 10.13.6
MacPro 2 x 2.4 GHz Quad-Core Intel Xeon ● 24 GB RAM
Avid HD I/O ● Sync HD ● AJA LHi referenced by AJA GEN10 ● D-Command ES24
Old 11-18-2018, 08:06 AM
Hi Michael,
I feel your pain, I did it a year or so ago when the writing was on the wall for SD2. Apple no longer supports the format, so you should do it fairly soon if you can.
I used Soundminer itself to do the job. It can batch convert and keep folder structure. I can't remember exactly how its done, but a quick search will bring it up. I think twisted wave can also do it, but if you have soundminer, may as well use that.
Back up beforehand, I know you will.
I had a few dodgy files that had become corrupted and wouldn't convert at all, but only a couple out of hundreds.
Old 11-18-2018, 12:14 PM
That's what the "mirror" feature is for. Works fine. Converts to BWAV while preserving meta-data and folder structure. SD2 will corrupt at some point I think because if this ancient "resource fork" or whatever it's called gets lost they can only be forensically recovered (has nothing to do with SM). I'd convert asap if you can with SM4.5.
The new Radium sampler is an awesome game-changer btw.
PTHDn 2020.5 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 11-18-2018, 01:13 PM
ubxf ubxf is offline
The sampler sounds promising but i couldn't find certain things that would be great to have. Can you loop sounds in the sampler ? Can you apply an envelope filter to the sound ? Can you do velocity switching of samples?
Also i'm still trying to find out how to save a patch, especially hoping it can retain plug ins settings. Definitely like the direction it's taking
Old 11-18-2018, 01:38 PM
Keep in mind that this isn't s sampler to produce your film score with so don't expect a full blown Kontakt-equivalent. It's mainly a sound design tool to quickly drop something into and also re-.record what you do within SM etc.
Having used it for quite a quite a while I actually like that it's extremely simple to use.
You can modulate the fx chain with an LFO (per slot that is) and there's envelope and pitch modulation, yes. Things like looping etc I hope will come (this is an early version afaik). At the moment you can't save a "patch" but Justin issues updates almost on a daily basis.
This is not the finished thing...hence the public beta phase...
Here's a detailed walk-though Justin made some time ago
https://www.youtube.com/watch?v=2FWxXtp_d8Y
Old 11-18-2018, 02:24 PM
Thank you for your reply, i totally get the fact that it is a sampler for sound design purposes and that it is an early version still under development but i'm hoping that a few more features are added to make it more than a convenient trigger with adjustable pitch. I found only envelope 1 could be assigned to modify parameters of the bass enhancer not other eq modules. I think as a sound design tool enveloped filter are nice to have especially when you have multilayers.
I used to follow the developments of V4.5 but i lost the link to the blog where Justin was posting the updates.
Also Thank you for the link to the detailed walk-through watching that was great and i loved hearing about the new relinking feature to fix broken audition path.
Old 11-18-2018, 10:20 PM
mgoorevich's Avatar
Thank you, Frank.
I tried to avoid dealing with my SD2 files as long as possible. Not anymore
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
Old 11-19-2018, 02:33 AM
New relinking feature? Which one? There has been relink for years. I probably missed the new one? Please do tell...
HTML code is On
WTB: Soundminer v4.5 Standard or Soundminer HD Plus Oliver M Buy & Sell 0 12-21-2014 01:50 PM
anyway to access Preview and Automation preview on PC or Edit vudoo ProControl, Control|24, Command|8 1 09-12-2009 06:49 AM
can't ear audiosuite preview, no sound from preview -SOLVED! sonuslab Pro Tools M-Powered (Win) 3 03-19-2008 12:51 AM
audiosuite preview / workspace preview fixed in 7.4? viaspiaggia Pro Tools TDM Systems (Mac) 10 10-11-2007 01:02 PM
