Old 04-24-2010, 01:43 AM
sad1robot sad1robot is offline
Default Committing midi parts to audio. All parts ahead of bar line
All my midi drum & synth parts are ahead of bar line when Committing them as hard disk audio tracks from External sound modules. you can see all kicks and synth parts are ahead of the grid bar line by about 1 /32 nd note. What is going on? Is this some time stamping /look ahead Midi setting?
Its not my sound modules. S 950 for drums - oberheim xpander are both triggering evenly AHEAD.
anyone experience this?
Old 04-24-2010, 09:50 AM
Howardk Howardk is offline
Default Re: Committing midi parts to audio. All parts ahead of bar line
To make sure I understand, you are saying that when you play the instruments via midi, and print that audio to a track, and go back and look at the audio after it is recorded, it is ahead of the actual midi notes that fired the sound? I have seen a lot of different thinks like this, some being bugs. Couple questions:
  1. Do you have Automatic Delay Compensation enabled and turned on(If yes, try disabling?
  2. Is there a value in the global midi offset or the midi offset for the particular tracks?
There are other things, but it is usually one of these. . .
See my Public Profile for System Configuration Information
(Click on member name)
Old 04-25-2010, 01:09 AM
scottgreiner scottgreiner is offline
It's a very well known, well discussed, and well whined-about problem with ADC and midi. Shut off ADC, print your midi parts, and all should be fine.
Comping MIDI parts....how do u guys do it? JLiRD808 Pro Tools 10 6 10-21-2012 11:46 AM
i move some parts then parts are unmuted... montreal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 05-08-2010 05:56 AM
Structure1.1 > selecting parts by midi? walter rohrbach Virtual Instruments 4 05-05-2010 08:14 AM
Import Parts of Audio rmo Tips & Tricks 2 04-10-2009 04:58 AM
How can I join 2 audio parts? midi25 Pro Tools M-Powered (Win) 2 04-16-2006 01:23 PM
