Old 07-20-2007, 01:34 PM
Jim Casey Jim Casey is offline
Default PRO TOOLS EXPORT TO CUBASE IMPORT TIMING ISSUE
Hey guys,
I am collaborating with a band in Holland that uses Cubase. I block and export track (like a bass solo) to a 24 bit wav in grid mode. Every time they import it into Cubase the timing is off and they have to slip and slide it.
Does anyone have any idea why this could possibly happen???? It does not happen in reverse.
Any help would be appreciated.
Thanks!
- Casey
Casey
You can hear what I'm doing at:
http://www.reverbnation.com/jimcasey
Old 07-20-2007, 01:52 PM
JMS40 JMS40 is offline
Default Re: PRO TOOLS EXPORT TO CUBASE IMPORT TIMING ISSUE
Left align all tracks to absolute zero before exporting.
That's the fool proof method.
Old 07-20-2007, 07:37 PM
mishar mishar is offline
Agreed,
Consolidating from bar 1|1|00 is the best possible solution.
If you're worried about file sizes for sending files via ftp, just zip (compress) the audio files.
All those extra zero's that are in the audio file will be compacted.
I've done this hundreds of times now, with no problems. Cubase to Protools and vica versa.
Old 07-20-2007, 08:45 PM
Hey you guys, thanks for the responses. Are you both saying I should only bounce from the top of the track and not, say, 10 measures from the middle?
Because I have been just taking a one minute section blocked out in grid mode and bouncing it - but from what I am gathering here - I should only do it from the top of the track?
Casey
Old 07-20-2007, 09:46 PM
Kris75's Avatar
Kris75 Kris75 is offline
Space Cabin Audio
Create 2 markers, one at the start of the Consolidation point and one at the end.
Double click in the marker ruler to highlight the selection. Then extend your selection across all tracks.
ALT + SHIFT + 3
Wait.
Export to new location/folder
Burn or FTP.
I understand not wanting to go to absolute 0 if you are using an FTP to upload tracks, but otherwise it is the best solution(as others have said.)
There will be no timing issues if all of the tracks are consolidated at once with the same start point.
Sign up for all things....AWESOME!
Kris
May the music move you
Old 07-20-2007, 10:33 PM
Well that seems to be it then - the whole track is a must. Anyone know WHY that is?
Casey
Old 07-21-2007, 02:51 AM
Kris75's Avatar
Space Cabin Audio
If you want time stamps then you can do that as well.
Consolidation is much faster though (unless it is just a few regions over an FTP)
Kris
Old 07-21-2007, 04:36 AM
We'll give this all a spin on the next round - thanks for all the advice.
Casey
Old 07-22-2007, 04:50 AM
Everything is still coming out 1/4 beat late. AHHHHHHHH!
Casey
Old 07-22-2007, 09:04 AM
Kris75's Avatar
Space Cabin Audio
Does there session start at 0? Does your session start at 0? (Beat 1/Bar1)
Kris
Pro Tools 11.0.2 Timing issue Cheskie Pro Tools 11 0 10-07-2013 12:40 PM
ProTools export to CUBASE import for mix bdeivert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-18-2007 11:01 AM
mpc 2000 and pro tools timing issue? fallout 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-28-2004 11:31 AM
File import from Cubase PC w/timing info? Ben Jenssen Pro Tools TDM Systems (Mac) 0 06-19-2001 11:40 AM
File import from Cubase PC w/timing info? Ben Jenssen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-19-2001 11:21 AM
