Old 10-21-2017, 07:09 AM
jjnssn jjnssn is offline
Default EuCon v3.7 Not starting on boot Windows 10.
Previously EuCon has always auto started at boot. McClient appears to load, however I have to manually run EuControl ,( happened with both 3.7 releases). Is this intended? I uninstall and reinstall when upgrading. Am I doing something wrong?
Eddie?
____________________________________________
W10 Pro / X99 / E5-1650v3 / 64GB ECC / nVidia P1000 / ASUS TB3 AIC
PT HDX1 / OMNI / HD IO 16x16 / 11R / Kontakt Kontrol S49 / Artist Transport and Mix / UAD OCTO Satellite, Apollo Twin MKII &, x8P Thunderbolt
[Late 2013 10.14 MacBook Pro]
Old 10-23-2017, 10:49 AM
EddieJones's Avatar
Default Re: EuCon v3.7 Not starting on boot Windows 10.
Check the new auto start options in the notification icon. Check the Whats new Guide for info.
Old 10-28-2017, 09:07 AM
Yep. Found it. I like the feature add a lot. Thank you.
Old 03-10-2020, 10:28 PM
sergemodular sergemodular is offline
Hello everyone!
Ok I'm having real similar problems here on this new DAW. I'm trying to get the Artist Control to work properly. I install it and everything works great until a restart or I shut off the computer. Upon rebooting / restarting the Eucontrol app will not launch manually. The program just won't launch where I can see it.
Now, here's the strange thing: The Artist Control still boots as normal. Cubase also sees it and it works. Since the Eucontrol program won't launch, I cannot edit any of the parameters in Eucontrol. So it's running, but I can't see it. If that makes sense.
I've tried the various things in the posts about this, that I'm able to without any luck. Some funny things, I don't get any notifications as stated early in the post. I turned on notifications and checked it. I do not see anything about Eucon. Also it does seem to be autolaunching as the Artist Control comes up and is usable. I've tried static IP's and Dynamic IP's and I get the same results. Eucontrol won't launch....
Any ideas how to get Eucontrol to properly launch here? It's frustrating.
Thank you in advance for any information!
Old 03-25-2020, 11:33 AM
EddieJones's Avatar
Have you checked in the tray icons ? If you can't see it press the little up arrow. if its connecting EuControl IS running.
Eucon crashes on boot when dock is ON. domilik Avid S1, S3, Dock and Control 0 09-10-2016 12:56 AM
Eucon Windows BUG: some windows r stuck in background when Eucon running. TuckerMix Artist Series 12 07-08-2014 01:37 PM
Magma EB4 - ExpressBox 4 (2U) - Windows boot freeze, not starting with PCIe HD3 Accel gandlz Pro Tools TDM Systems (Win) 5 02-11-2014 09:16 AM
Digidesign 192 boot issue, sometimes not starting up correctly gandlz Pro Tools TDM Systems (Win) 12 07-15-2013 10:15 AM
