Old 05-06-2016, 05:11 AM
tonyreed tonyreed is offline
Default Hard drive questions
Im having trouble with my external HDD with it not letting me save and telling me its too slow ( its 5400 rpm) . So before I go upgrade the whole thing I would appreciate any help with these ( probably) basic questions
Im using a firewire interface ( focusrite saffire) so should I daisy chain the hard drive? i.e out of the Imac - into the HDD and then out of that into the focusrite?
Is there any advantage to thunderbolt cause I was thinking of getting a thunderbolt converter and i presume I wouldn't mix up firewire and thunderbolt?
Thanks for your help
Tony
Old 05-06-2016, 05:52 AM
Becharax's Avatar
Becharax Becharax is offline
Default Re: Hard drive questions
you need a usb 3.0 7200 RPM and you will be good to go ... 5400 are not for audio recording .. just backup drives
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
macOS 10.14.6
Pro Tools 2019.12
Logic Pro X
Reason 11
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack SPDIF/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad Thunderbolt
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Ibanez Pedals/Fender Strat/Acoustic Yamaha Guitar
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840
http://www.youtube.com/becharasaliba
Old 05-06-2016, 08:32 AM
What exact model iMac do you have today? With exactly what peripherals connected to it?
The last thing to look at is a old external FireWire HDD, they belong in museums or landfills.
The best options may be a USB3 or Thunderbolt connected SSD. Lots of options there from simple USB SSDs like the Samsubg T3 up to external Thubderbolt docks with SATA or even PCIe slot or PCIe M.2 SSDs installed in them, or pre-built Thubderbolt Little Big Disk2 drives from LaCie with PCIe M.2 (if you wanted extreme performance).
The more info you can provide about your setup, including all the drives you are using for boot/system, samples and audio, your sessions (#tracks and sample rate). The more folks here will be able to give you specific advice. You do not want to be running on a 5,400 rpm drive, but Pro Tools 12 with disk cache properly enabled will tend to help a lot with many disk performance issues. still I would only look at SSDs for session drives. HDD for audio/backup drives and if needed for large sample libraries and video where SSD cost may be problematic.
Old 05-06-2016, 09:08 PM
Thankyou Daryl here is what I have.
Imac 21.5 late 2015 2.8 Ghz core i5 8GB 1867 DDR 3 USB 3.
Interfaces are a Focusrite safire 56 with 2 firewire 400 ports.
My session drive is a 1TB G drive with 2 firewire 800 and 1 USB 3 Im pretty sure its 5400 rpm.
I also have an old Hitachie HDD with a 80O firewire I use for backup.
The Imac has 4 USB 3 and 2 thunderbolts.
I have the G drive connected to the imac with a firewire/ thunderbolt adapter and then its daisy chained to the focusrite with a 800 to 400 lead.
The backup dive is just connected to the i mac with a firewire to thunderbolt adapter.
Seems like a mess when I write it down here.
Thing is I really only use audio and no more than 12 tracks. A little bit of midi and I dont have a separate sample drive cause I dont use them.
Im using PT 12.5 and have some basic waves plug ins. Latest version of El capitan.
Problem is bought the dam fousrite just before everything went to thunderbolt. I assume I cant mix up USB 3 with the fire wire on the fousrite. I have been wanting to change it out for a decent converter as i have my own decent pres.
I hope all this helps and I would appreciate any suggestions advice on what I should do. Cheers Tony
Old 05-06-2016, 09:11 PM
G-Drive? You mean G-Tech. That likely won't be a 5,400 rpm drive, it will be 7,200. What exact model is it? Go Google the model number and find out.
If its a 7,200 rpm drive and you are getting this error you should make sure the system is properly optimized and then go though the standard troubleshooting. You may be wasting your money on a new drive. But a Firewire drive is not a good idea on the firewire chain if it can be avoided, and the USB on that drive is what? USB 2? That's slow. there is also the issue of chaining sequence with the Firewire interface and drives. You should be chaining the FW400 interface off the FW800 drive, but sometimes have to also try the opposite.... or get two Apple FireWire adapters. and tun them off separate Thunderbolt busses.
These errors can also caused by too small playback buffer for the system, bad plugins, trying to run at too high a session sample rate, corrupt sessions, etc. Start with trashing prefs and looking at these things (see standard troubleshooting under the "help us help you" link up top of this web page). Do all troubleshooting with "ignore errors" *not* checked. One thing you can try as well is setting the playback engine to built-in output, disconnect the interface and rung the disk directly on the Thunderbolt to Firewire adapter and see if you still get the error. Once you have done that troubleshooting and hopefully found issues then make sure disk cache is turned on (set to a size in the playback engine dialog, start at 2GB, not set to "normal"==off).
If all that does not work then I would grab a Samsung USB 3 SSD http://www.amazon.com/Samsung-Portab.../dp/B01AVF6UQQ Maybe just grab that drive anyhow. Your life will likely be a lot easier not wasting time with a Firewire HDD.
Old 05-07-2016, 02:26 AM
Thanks Daryl
Youre right about the drive. It is 7200.
Its also an USB 3. So if thats the case whats the best way to join it all up? Can I go from Imac Usb3 to hard drive Usb 3 and then use the firewire 800 port on the drive to connect to the firewire interface. Or just conect then to separate buses on the I mac one usb 3 the other firewire. Ill do all the trouble shooting stuff too.
I appreciate your help.
Cheers Tony
Old 05-07-2016, 03:39 AM
VRW VRW is offline
+1
Thatīs always a good idea just from experience.
Get another Firewire-to-Thunderbolt-Adapter and connect your Saffire to one TB port (put a FW800-to-FW400 adapter cable into the
FW-to-TB-adapter), your Hitachi HDD to the 2nd one for backups.
From my personal experience decent quality FW800-to-FW400 adapter cables do work better with interfaces than those connector plugs.
http://www.amazon.com/Citi-Electroni...0+to+400+cable
Then connect your Session drive to one of your USB 3 ports, just make sure you have a new, good quality USB 3(!) cable (sometimes
people just use standard USB 2 cables for USB 3 drives which will not provide the desired increase in speed and stability finally).
This will speed up your session drive a lot (and solve the issue if itīs coming from a defective FW cable or FW port)!
As for speed a 7200rpm HDD via FW800 runs at about 60-80mb/s Write/Read at the max, the same 7200rpm HDD via Thunderbolt/USB 3
goes with about 160-170mb/s. Thatīs quite a difference in speed actually.
Btw no, you canīt mix USB 3 and Firewire within a chain.
Like Darryl already mentioned there might be other reasons for your errors. He has covered it all obviously.
If trouble shooting will not bring the desired success I would advice to (Iīm aware of that people donīt like this advice a lot) back up all
your stuff first and then do a complete clean install of your whole system. This often is the best solution finally.
As for your interface/converters if you can afford it in the future you might check out this little Thunderbolt audio interface as you said you
would not need many pres in the interface itself because you got your own decent pres.
http://www.sweetwater.com/store/detail/Clarett2Pre
https://us.focusrite.com/thunderbolt...rett-2pre?rd=1
This one got really good converters for the price and itīs Thunderbolt connected which would perfectly suit your 2015 iMac. Offering the
lowest latency on recording on the market and 8 ADAT inputs obviously.
If you would need 8 ADAT Outs as well itīs bigger brother may be worth checking out as well but this one has got 8 pres built in as well.
Very good ones indeed.
http://www.sweetwater.com/store/detail/Clarett8Pre
https://us.focusrite.com/thunderbolt...s/clarett-8pre
+1
The most affordable yet very fast, good quality option will be this one.
Put such a one
http://www.amazon.com/Samsung-2-5-In...amsung+850+Evo
into such a one
http://www.amazon.com/Optimized-Inat...+3.0+enclosure
About 380-400mb/s Write/Read and definitely reliable enough for the work with PT12. Pretty nice for the price actually.
Again, if you cannot solve the issues by trouble shooting and reconnecting your external devices (check all your cables as well!), do yourself
a favor and perform a clean install of your system including setting up all the optimizations in your OSX before installing PT.
http://avid.force.com/pkb/articles/t...Optimize-10-11
This might help to solve it finally.
The best of success to you, VRW
Old 05-07-2016, 06:07 AM
Originally Posted by tonyreed View Post
Thanks Daryl
Cheers Tony
Well 7,200 rpm and USB3 changes everything. You should be running that drive off USB3 now, and your interface off a Thunderbolt to FireWire adapter. The drive does not/can not convert USB3 to FireWire (no peripheral can).
Start there, if that does not immediately fix things you likely have a totally different configuration, optimization, or software problem not related to the drive (even if you get errors saying the drive is too slow).
Old 05-09-2016, 02:53 AM
Thanks Daryl and VRW i have changed the connections as advised and cleaned up prefernces as well. So far so good. There is certainly some good help to be had on this site. I should have read the help us help you site first. Cheers Tony
The
Old 05-09-2016, 06:08 AM
nigelpry's Avatar
nigelpry nigelpry is offline
Don't get me wrong Darryl, I wouldn't advocate anyone with a non-FireWire equipped computer buying into FireWire as a protocol nowadays, but I think it's a little harsh to say they only belong in museums and landfill.
They are capable of delivering enough throughput for most people's needs.
I've recorded 48 tracks at once, and at mix time I've had more than 100 tracks playing back without any complaints from the FireWire drive or the computer trying to suck data off it.
Yesterday's tech... Yes ... A museum piece ... Not nearly! Still useful? ... Yes ;-)
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10
Macbook Pro 2011 17", 2.2ghz i7, 16gb RAM OS 10.12.6
Digi 003 Console, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors.
Pro Tools 2020.3, Media Composer 8.9, Sibelius 8.7, Cubase Pro 10.5, Wavelab Pro 10, Logic Pro X 10.4.8, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
G5 + hard drive questions GSM79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-02-2004 04:11 AM
*HARD DRIVE QUESTIONS!* instro001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 08-17-2004 02:07 AM
hard drive questions....again nightshadecrisis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-12-2004 10:38 PM
Hard Drive Questions blameus_product 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-06-2003 05:11 PM
Hard drive questions Niklas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-30-2002 03:33 AM
