Analog or S/PDIF ?
Hey
I'm connecting a MAC and a PC to work simultaniously. My question on this post is, for recording stuff from one to another, just I have the computers connected with analog 1/4" or via S/PDIF ? I have a couple of soft synth that I play on my PC, and want to record them on my MAC. Right know I have 1/4" out on PC and 1/4" In on mac. But I get a little huumm noise. Will S/PDIF correct this ? Can I get the same phat sound with it ?? |
Re: Analog or S/PDIF ?
Use SPDIF whenever you can to remain in the digital domain. Yes you should eliminate the hum at the same time since it is a digital signal. Also, plug everything into the same wall plug to avoid ground loops.
I hope you are not thinking of using the PC or MAC's sound card as one of your sources. You'd be better off sending the MIDI notes to your M-Powered hardware and letting them be processed in PT-MP. |
S/PDIF or analog output? | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-01-2007 12:13 PM |
difference between s/pdif and analog | jtll24 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-28-2006 04:13 AM |
S/PDIF vs. Analog Inputs | emelare | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-16-2005 07:55 AM |
Analog or S/PDIF on vocal? | booinec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-24-2004 09:16 AM |
Recording with S/PDIF and analog I/O | strat12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-29-2002 02:11 PM |
