Old 01-12-2021, 08:56 AM
studiosus studiosus is offline
Default option for select button stay select in shift mode
I enjoy a lot the new function of cycling eq and dynamics. But since the eq and dynamic function is on the same knob on the artist mix you need to use the shift mode for the dynamics. If you do that and select another track while accidentally still in shift, it opens the assign window in eucon. That happens to me quite often and breaks the workflow completely (yes you can unlatch the shift behaviour, that helps but comes with some disadvantages for other usage- and yes, if you like to do a new layout, it´s great to do that with that button).
It would be great to have an option in the eucon preferences to let the select button stick to the select command also in shift.
Or what also could be great, would be the dynamics and eq function available as a soft key. So you could put that on whatever two dedicated buttons on a artist transport for instance.
Old 01-13-2021, 09:10 AM
EddieJones's Avatar
EddieJones EddieJones is online now
Default Re: option for select button stay select in shift mode
Thats a great idea....but I know it would be quite a lot of code to make it work correctly. I'll keep it in mind though. Thanks
Old 01-14-2021, 02:52 PM
That would be very nice. Kind of similar to the preference for the mute/on and solo buttons on to stay always mute and solo, which I complained about that some years ago, no?
Many thanks for the integration lately! Helps me out a lot!
Avid S1: Select Button Behaviour DaveMan Avid S1, S3, Dock and Control App 2 01-31-2021 11:12 AM
Shift Select Doesn't work Kylehamilton Getting Started 10 10-14-2015 01:02 PM
Select Button and screen visualization mik ICON & C|24 11 11-07-2010 11:54 AM
Unable to (de)select a...z button Studio Studio Pro Tools TDM Systems (Mac) 2 09-06-2007 05:15 AM
