Issues with protools and presonus studiolive
I am new to protools and was wondering if someone can help me with a issue I am having? I have protools 10 with a presonus studiolive 24 interface and using a iMac. All the settings on the mac and protools are set to use the presonus for input and output but when I try to select the input/output on the individual tracks it only has the built it mics from the mac. Is there some setting I am missing to get the presonus to show in the input/output selector. I get sound in and out of the presonus and extenal monitors but nothing registers on the track. Sorry if this doesn't make any sense I don't know much protool. Thanks in advance. |
Re: Issues with protools and presonus studiolive
Go to playback engine and set the presonus as the audio engine/interface in the pull down menu for audio engine. In the hardware setup page. make sure the inputs and outputs are assigned to the appropriate analogue or digital inputs and outputs for the presonus in the I/O setup page make sure you have created inputs and outputs and named them and they are assigned to the presonus inputs and outputs etc. Chris
Thanks, I'll go back and double check my settings.
PT 11 with Presonus Studiolive 24 | daaebro | Pro Tools 11 | 8 | 02-18-2014 05:58 PM |
Having issues with Presonus Studiolive and thunderbolt | gabotb | Third Party Interfaces | 0 | 01-23-2014 10:11 PM |
Presonus Studiolive 16.4.2 and PT 10 | marko_salo | Pro Tools 10 | 0 | 08-17-2013 10:49 AM |
Presonus StudioLive console w/Protools | teacherman | Pro Tools 10 | 2 | 04-13-2012 12:38 PM |
Presonus StudioLive with PT9 | teacherman | Pro Tools 9 | 3 | 01-22-2011 06:32 PM |
