Unable to start PT 6.2.2 w/ Mbox and 1.25 PB
I'm using an Mbox wiht a 1.25 GHz powerbook and the program while loading each time. it gets to the "Setting up MIDI" step and then crashes, giving no error message. PT is installed on an external firewire drive, which functioned fine back in 10.2.8 and 6.1. No other periferals are connected to the computer and nothing else is running. Any advice. Thank you
Re: Unable to start PT 6.2.2 w/ Mbox and 1.25 PB
are you running OS 10.3.1? That's the version you need with 6.2.2. Also, having PT installed somewhere other than your system drive is highly discouraged, that might be the cause. Check your Audio MIDI setup and make sure it's representing your studio correctly.
Pro Tools 9 unable to start up. | TechNAB76 | macOS | 9 | 08-25-2012 11:26 AM |
Unable to start new sessions in LE 6.7 | Seth Everhart | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-25-2005 04:36 PM |
unable to use 002 after start up | nitogrenada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-17-2004 02:02 PM |
unable to start my Pro Tools | Ondrej Malina | Pro Tools TDM Systems (Mac) | 3 | 10-14-2002 08:50 AM |
unable to start my Pro Tools | Ondrej Malina | Pro Tools TDM Systems (Mac) | 7 | 10-03-2002 11:57 PM |
