Re: Mixing PT on a G4 laptop
How many tracks from what source? MBox is great for portability but only can record 2 tracks at a time. The 002R is great but it would require a little more space and a power supply.
I have had a lot of luck (PT 5.2 on OS9) with a 600 Mhz iBook, the MBox and an iPod for hard drive. Nothing very complex but I didn't need any power supplies and the quality was great (total portability). |
Mbox works nicely as a mobile hardware i/o.
You'll probably also need a good pair of headphones. I get good results with a pair of Beyer DT100s. I know these very well and the mixes i do on them transfer to playback on speakers suprisingly o.k. Mbox has pretty powerfull headphone amps and will drive my 8ohm DT100s to a seriously ( dangerously ) loud level if needed. When you say your on the road, do you mean a bus? If so, get a mouse as the vibrations make the track pad very fiddley. Also get some of that rubber mesh from a camping shop and maybe some blu tack to stop things sliding about. 002 maybe your thing, but then you will rely more on the bus power. Telling a huge Texan driver that he crashed my sampler when he switched over from the generator to the land line did not illicit much sympathy ! |
I use my M Box for mixing just get a extended keybaord and mouse.
Wiz
The underground is as fickle and shallow as the mainstream. |
I was hoping there was something smaller. I just want to play back...not record. This is just for rough mixing and editing. I am spending a ton of time on planes and waiting at airports. I want to go as light and small as possible!
Looks like Mbox is the only solution..yes? It's not like I have a choice here..right? |
Mbox it is, final answer.
www.myspace.com/krou |
Mixing on a laptop | tdblanchard | macOS | 5 | 05-23-2013 07:57 AM |
anyone mixing for TV in LE on a G4 laptop? | inky | Post - Surround - Video | 19 | 08-16-2006 02:09 PM |
I need advice regarding mixing to a laptop | Imagine | Pro Tools TDM Systems (Mac) | 10 | 10-04-2004 05:42 PM |
mixing/editing on a laptop | PlainJoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-23-2004 05:01 AM |
mixing on a laptop...do I need the 002 connected? | BeachDog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-06-2003 12:44 AM |
