Old 06-07-2022, 04:00 PM
RichrdC RichrdC is offline
Default Re: xPand2 question
So I uninstalled the version downloaded from my Avid Account and followed the link above and downloaded that version.. Successful download, sitting in my Download file. Of course, ProTools 2018.4 when starting up, didn't download it. XPand!2 was ignored. I watched. And the plug isn't showing up in the plug in menus.. I seem to think there's a fix to this, but I can't remember.. Any ideas before I call the PT Tech One Time incident folks? I do have a question. If the version now downloaded is newer than PT2018.4, would that be an issue? Take care and thanks in advance for any insights
Old 06-08-2022, 01:01 PM
Sitting in the Downloads file is not installing it
Old 06-08-2022, 09:20 PM
unkJE's Avatar
unkJE unkJE is offline
Unfortunately, Xpand!2 version 18.3 doesn’t install the Presets (whereas Xpand!2 version 18.1 does), but while 18.1 remains unavailable in Avid Download Center, there’s still a workaround:
First install Plugin Boutique’s Xpand!2 version 2.2.7.21000 from:
https://help.pluginboutique.com/hc/e.../6232248078612
It’s VST/AU only – doesn’t include AAX – choose “Run as administrator”
Uncheck “Install Factory Content (choose location)” – just install the VST
Cut the Folder called “Presets” from:
C:\Program Files (x86)\AIR Music Technology\Xpand!2\Presets
Paste the Folder called “Presets” on your Desktop
Uninstall Xpand!2 version 2.2.7.21000 in Windows “Programs and Features”
Install Xpand!2 version 18.3
Double-click on the Xpand!2 Plug-In in:
C:\Program Files\Common Files\Avid\Audio\Plug-Ins
Double-click on the Contents Folder – create a 3rd Folder within the Contents Folder and call it:
Factory Presets
Rename the “Presets” Folder on your Desktop – call it:
Xpand!2
Copy this Xpand!2 Folder and place it in the Factory Presets Folder within the Plug-in
Cut the Xpand!2 Folder on your Desktop and paste it here:
C:\Users\Username\Documents\Pro Tools\Plug-In Settings
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor
Old 06-10-2022, 09:31 AM
Success!! Thank you unkJE.... Thanks for posting clear steps for the work around.. There's was only one spot that was a little vague, at least to me!! After downloading 18.3 you instructed to "Double-click on the Xpand!2 Plug-In in:
I never double clicked the Xpand!2 plug.
I wasn't sure what to do because I didn't see the Xpand!2 plug-in specifically when I went to the address on the C drive, I right clicked in the Patch Content folder, created that third folder Factory Presets, and carried on... I guess I was lucky because it's working..
Thanks again
Old 06-10-2022, 10:15 PM
unkJE's Avatar
... There's was only one spot that was a little vague, at least to me!! After downloading 18.3 you instructed to "Double-click on the Xpand!2 Plug-In in:
I wasn't sure what to do because I didn't see the Xpand!2 plug-in specifically when I went to the address on the C drive ...
Sorry for any confusion – the Xpand!2 plugin was probably installed in this Folder:
C:\Program Files\Common Files\Avid\Audio\Plug-Ins\AIR Music Technology
Anyway - it's really good to read you got it working!
A few extra points:
I have AIR Instrument’s Samples on an external SSD with Xpand!2 located here:
Samples:\Sound Libraries\AIR Music Technology\AIR Content\Xpand!2
(The AIR Content Folder was installed by another AIR plug-in, so I just kept it)
Those who installed Xpand!2 via the Pro Tools Creative Collection will probably have a Folder named Xpand2. If so, add an exclamation mark – rename it: Xpand!2
This folder contains the “XPand2.big” file
Use 4 separate MIDI Tracks with one Instrument Track for Xpand!2
There are some handy videos, if you haven’t seen these already:
Pro Tools First Tutorial (Part 4) – Xpand!2 Virtual Instruments
https://youtu.be/eCmk1vk9aKw
Pro Tools 11/12 - #27 - MIDI Tracks and Channels with XPand!2
https://youtu.be/gE3WmwVxedo
Using Automation with Xpand!2
https://vimeo.com/channels/protoolse...usive/37422751
Control Automation with Encoder – set to 4 Encoders to CC111, CC112, CC113, CC114.
Right-click on any LEVEL Fader – select Learn MIDI CC.
For others who want to use Xpand!2:
On AIR Xpand!2 – InstallShield Wizard Custom Setup page - click on drop-down arrows alongside “Xpand!2 Plug-in” and “Xpand!2 Content” and choose for both:
“This feature, and all subfeatures will be installed on local hard drive.”
This will install the Content to:
C:\Program Files\AIR Music Technology\XPand2
To install Content elsewhere (such as a separate external “Samples” drive) – hit the “Change” button to choose your separate location
Once installed, click on ‘air’ (on the bottom RH corner of Xpand!2 plug-in in Pro Tools) to show which version of Xpand!2 you have installed
Note (with greetings and salutations!) to Sir jeffro:
If you replace the current AIR XPand II 2018.3 Win in Avid Download Center with AIR Xpand II 2018.1 Win, the Presets would automatically be installed (within the plug-in) here on Windows:
XPand!2.aaxplugin\Contents\Factory Presets\Xpand!2
  #16
Old 06-12-2022, 09:09 AM
Default xPand2 question
Thanks for posting the video links. I'm definitely gonna take a look..
While I'm here, maybe you have a quick answer to why the volume on the plug-in is so very low I can't even hear it? When Record enabled, I know it's sounding only because the meter bar reacts off the bottom of the Mix strip a tiny little bit. I've tried turning the volume up in the plug-in itself and of course, the channel strip volume as well, and that hasn't done anything. Is there a setting somewhere that I need to check?
Thanks again for your help on all this. take care
  #17
Old 06-12-2022, 04:46 PM
Low volume compared to what? If its the only thing you are listening to, then it might be as simple as turning up your speakers or phones. Or, what is the Velocity value for your notes? Click on any note and the Midi info window will show that value(if its above 85 or so, that should be good. If its well below that, some setting needs to change). If you are dropping notes with the Pencil tool or Smart tool, you can set the default Velocity value(and I would start at 100-105 until you find you need otherwise. A simple comparison would be to put up another Instrument track and insert MiniGrand. That seems to be a VI that makes for good testing on most things midi.
  #18
Old 06-13-2022, 02:12 AM
unkJE's Avatar
Originally Posted by albee1952 View Post
... A simple comparison would be to put up another Instrument track and insert MiniGrand ...
Yep - just 2 Instrument Tracks is all you need to test.
My guess – as you’re seeing some meter activity, but hearing nothing, is that you’re using a Keyboard Controller, without doing your Pro Tools MIDI Studio Setup. If so, from the Pro Tools Menu bar, go to:
Setup>MIDI>MIDI Studio Setup
Hit the “Create” button
Instrument name will read: “New Instrument 1”
Select your Keyboard Controller from the “Manufacturer” drop-down arrow – if it’s not listed, select “None” at the very top of the list
Select the Output Port from the drop-down arrow
Close MIDI Studio Setup
Hit “Save”
Also - in Pro Tools Setup>Preferences>MIDI, select (under Default Through Instrument) – “First selected MIDI track” - Hit “OK”
Close Pro Tools (Alt + F4)
Restart computer
Launch Pro Tools
Load Xpand!2 with one to four Presets
Hit a note on your Keyboard Controller to audition sounds
There’re a few more videos here:
How to Get the Most Out of Xpand!2
https://avid.secure.force.com/pkb/ar...-Out-of-Xpand2
Xpand2 Question GNRMatt Getting Started 2 05-14-2021 03:44 PM
Xpand2 Question paperplanets Tips & Tricks 3 08-09-2012 10:20 PM
Xpand2 question DonaldM Virtual Instruments 8 08-17-2009 06:39 PM
Xpand2 Loops question rockdude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-11-2009 09:46 AM
XPAND2 Question drebeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-25-2009 08:29 PM
