Old 02-19-2022, 03:39 PM
bkfinch bkfinch is offline
Default ASIO4ALL, PT 2018, Windows 10 Audio Issue
I have been using 2018 for a few years now, with Windows 7 and ASIO4ALL. Everything has been great - no issues whatsoever. After being "forced" into upgrading to Windows 10 the sound quality has dropped drastically. I never had ANY issue with this before switching to Windows 10. Nothing in my setup has changed at all except the Windows 10.
I have a small set of studio monitors with a headphone jack on the front of the right monitor. This same monitor also has the on/off control knob that controls the volume as well. This is how I have always worked in Pro Tools since the beginning.
NOW - since switching to Windows 10 the issue is that in order to listen to anything I am working on at a decent/comfortable level, I have to turn the volume knob up to about the mid-way point. In doing so, I also get a lot of "air" or "hiss" that was never present before. Again, before the switch to Windows 10 everything was perfect. I could have that volume knob at about "9:00" or lower and get perfect sound.
Needless to say, this new development is effecting everything. I have trouble setting levels, recording, mixing - because I have to turn the volume up so loudly to hear well and try to overlook the "air" or "hiss" I'm hearing as well.
Any help would be greatly appreciated.
BTW - when I use these same speakers/headphones through the Realtek sound card on my computer for other audio - ie. YouTube videos - (in other words, not using ASIO4ALL) the sound is perfect as it should be.
Old 02-20-2022, 02:09 PM
Default Re: ASIO4ALL, PT 2018, Windows 10 Audio Issue
I assume you have no dedicated audio interface? Start by opening Windows Sound Properties and making sure that everything is turned up all the way. My personal recommendation will not be what you want to hear, but....using a dedicated audio interface for Pro Tools(or any DAW) is going to give better results in almost all cases. You don't need to break your wallet. Something like the Focusrite Scarlett 2i2 is plenty
Here's a link to a list of several options:
https://www.sweetwater.com/insync/be...io-interfaces/
Old 02-20-2022, 02:33 PM
Hi Dave. Thanks for your response. I checked to see that all windows audio settings are at 100%. I do have a Focusrite Scarlett Solo. Same situation. It worked 100% perfectly for me until the Windows 10 update. It actually does the same thing my speakers do. I wish there was a way to record what it's doing so folks could here it. The best way I can describe it is this: When I'm all plugged in and have my headphones on, I hear 100% complete silence. Then I launch Pro Tools. As soon as I select my session finishes loading - ready to go - I suddenly hear what I can describe as "air" - almost like what it sounds like when you hear an A/C running through a microphone. The only way to get rid of the "air" noise is to turn the volume down on my speakers to about the "7" on a clock face. This gets rid of the "air" sound, but of course then I have trouble hearing my session. As soon as I close Pro Tools, the headphones are once again silent - no "air" noise. Very frustrating. Again - thanks for the response. Any other thoughts?
Old 02-22-2022, 02:32 PM
I would uninstall ASIO4ALL and the Focusrite driver and go to their website and download the latest driver(and cross your fingers).ASIO4ALL has always been a band aid solution when nothing else works. Focusrite usually has okay drivers, but its been a long time since I used their interfaces(been on HDN/192 for many years here)
Old 02-22-2022, 02:43 PM
TOM@METRO's Avatar
It may be system specific, but ASIO4ALL has never worked well for me on Windows 10 with Pro Tools.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-22-2022, 05:03 PM
Thanks Guys. Turns out, I'm just an idiot. I actually prayed for wisdom to figure this thing out. The next day the thought occurred to me - try muting tracks one by one - without pressing play - to see if the noise would go away. Turns out this entire time it was a plug-in on one of the tracks that was the culprit. Removed that plug-in and was back to complete silence. I feel like an idiot. I guess we live and learn. Thanks again for trying to help. I really appreciate it.
PT 2018 windows position multi monitor issue mhender Pro Tools 2018 19 05-04-2023 02:33 PM
Headphones Output missing in ASIO4ALL, invalid in Windows Audio Device Desande Pro Tools | Intro Discussion 9 10-20-2017 11:11 PM
BSOD Windows 10 ASIO4ALL djbigkraq FireWire & USB Audio Interfaces (Win) 0 03-28-2016 08:12 PM
Asio4all 88.2 playback issue benherron.rrr Windows 2 09-22-2012 10:32 AM
