  #31
Old 01-05-2022, 10:08 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: No Output in Low Latency Mode
Low Latency Monitoring is very unneessary feature, just turn it off.
Janne
  #32
Old 01-05-2022, 10:13 AM
Originally Posted by Richard Culver View Post
This feature, whatever it is intended to do, seems to kill the monitoring for any track you are are trying to record to.
Should it not be labeled low latency playback monitoring?
It is doing exactly what it is designed, and documented, to do. Disabling software monitoring so that hardware monitoring can be used to input monitor live input tracks. It’s that simple. If you want to use hardware monitoring it can be a nice workflow approach, if you don’t then don’t use it. All explained in the Pro Tools Reference Guide, but complicated by multiple references to low latency monitoring for HD Native vs. CoreAudio/ASIO interfaces… make sure you are reading the right section.
  #33
Old 01-05-2022, 07:11 PM
Richard Culver Richard Culver is offline
Thanks ! That makes sense. I will put in a feature request to address the confusing label. Maybe not to vets but new users for sure.
Richard Culver
Windows 10 64 PC Intel Core i7 9700 3ghz 64 GB RAM
NVIDIA RTX 2080 8 GB VRAM
Eleven Rack - connected to USB
RME Fireface 802 (connected to fire wire)
Low Latency mode verb305 Pro Tools 9 4 11-27-2010 12:03 AM
Where's my Low Latency mode gone? philster65 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-01-2010 12:53 AM
002 - While in Low Latency Mode, HOW...... bflat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-29-2005 07:49 AM
low latency mode conbreaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-20-2005 05:24 PM
Low Latency Mode not available Kevin P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-12-2005 07:42 AM
